Go to Post It's a twitter post. It's not a hint. - Libby K [more]
Unread 17-02-2003, 16:36
Chris Nowak Chris Nowak is offline
Soudeska?
#0074
Chris Nowak is an unknown quantity at this point
Plz help with codec
What codec did everyone use? I know there is another thread about it but I didnt see that one end in a general consensus about what compression was the best. I just tried encoding it with Cinepak and Indeo, and both sucked majorly. What compressor do they want with Quicktime? I'm using premiere, after I select that I want a quicktime in the general rollout, It also needs a compressor, so what should I use for that?
MSN Messenger - chris_nowak91@hotmail.com
Team 74 - Top Seeded Team in Galileo Division
Unread 17-02-2003, 20:51
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
We used indeo 5.1 in premiere and it worked just fine
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 17-02-2003, 20:52
samh57 samh57 is offline
samh57 is an unknown quantity at this point
divx
Unread 17-02-2003, 20:58
MBiddy's Avatar
MBiddy MBiddy is offline
Groovy!
#0862 (Lightning)
MBiddy is an unknown quantity at this point
Send a message via AIM to MBiddy
You might want to rethink that divx codec. Some other people posted emails from FIRST about this topic (I'm pretty sure it was in one of the updates too) that said they wanted it in Cinepak, Quicktime and some other one, Indeo I guess. I'm not sure what we're going with yet.
Unread 17-02-2003, 21:24
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Im submitting on Mpeg-4 for quicktime....looks really sweet (its 75 megs, but its all good )
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 17-02-2003, 21:51
Soudeska?
#0074
aaahh....I see my problem. I accidentally picted version 3.2 of Indeo, thats why it sucked so bad. Well, I compiled it with v5.1 and it looks much better. Thanks!
Unread 18-02-2003, 12:57
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Our largest problem with codecs is that no matter what quality it is encoded at (we are experimenting with different Quicktime codecs) the video appears to stutter from time to time. This looks like a performance issue (in other words, the frames are actually there, but PC does not have to time to decode them) but i believe my machine should not have much problems with playing the files in real time. (its a 1.4 ghz athlon with 768mb pc133). Even reducing the quality to 50% at 500kbit/s in sorenson3 produces noticeable stutters. Can anyone give an advice on a high quality codec with fast decoding performance?
Any help would be really appreciated.
Unread 18-02-2003, 16:15
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
We've been rendering uncompressed (as you all should ) and then creating a final output in QuickTime using SORENSON 3 - It playsback fine for us. I do a lot of tests with half resolution (320x240) to make sure all looks fine. But the final will be the 640x480 and will be 100% Compresion quality.
These files should have some trouble playing, they are not designed to be played on a standard pc. These files are designed to go to a video edit system, then to tape or to be furtuer compressed for CD or DVD or Web Streaming. To test it you can try a VideoCD of your file un less you have a DVD burner. It should play better that way (but not sure).
I always work in uncompressed formats for work or I use the Avid Codec at a 2:1 setting- This is a great Codec because you can download it for free and use it with AVI or Quicktime formats. It CAN'T be used for the competition because it a D1 Video Format (which is 720x486) this format uses non-square pixels and is a standard video format for high end edit systems. You can use it on other projects and save a ton of space w/o using any real quality(at 2:1) at any noncompressed codec setting you will lose nothing. Other compressions will lose quality and will get worse the more you compostie and rerender (a process I use all the time)
Missing Item plz help! Cory Chit-Chat 12 06-05-2003 00:39
Autodesk Codec Response!!! Specialagentjim 3D Animation and Competition 37 15-03-2003 19:57
Codec Specialagentjim 3D Animation and Competition 20 05-02-2003 23:09
HELP W/ CONVERTING FILES PLZ... Matt Attallah Chit-Chat 3 03-01-2002 18:47
Mark Leon plz be our MC again! Patrick Wang General Forum 1 10-12-2001 18:02
