#106
Re: Team 254 Presents: Barrage
At approximately 6.5 points/sec it is a bit of a shame that you have to play teleop.
If you were able to keep up the points per second rate from auto in teleop, you would score approximatlely 975 points by the end of a full match. |
#107
![]() Last edited by Electronica1 : 04-03-2014 at 19:18. Reason: Grammer is not my friend today... |
#108
Anybody have a good picture of this linkage? I'm not exactly sure what part is being referred to here.
#109
Clean robot, as usual! Some clever use of pneumatic linkages and latches, very cool. I like how the deflector for the shooter is just floating up in the air on the end of a big moving frame.
I noticed a sponsor sticker on your robot that I haven't seen before... Team Whyachi. How is that working out? Do you have a rotational kinetic mechanism we can't see, or perhaps a new walking drivetrain? Last edited by s_forbes : 04-03-2014 at 20:21. |
#110
A really impressive robot. I like how the design is centered around the 3 ball capability for autonomous. This would definitely provide you with the flexibility to pickup from both sides in tight defensive situations. Amazing as always, Poofs!
#111
#112
I'm guessing that "CIM" in the belly of the robot is actually a Thomas 215 compressor. The motor on it looks a lot like a CIM.
#113
What are those gray covers on the pneumatics tubing just before it goes into the fittings?
#114
http://www.mcmaster.com/#4512T6 Last edited by TD78 : 05-03-2014 at 10:57. |
#115
That makes a lot more sense. Previously I had only seen the gray colored Thomas compressors from past KoP's.
#116
Most importantly, they are super fast. DXF's were sent to them Sunday night, parts cut and shipped out Monday AM within hours. They stock most sizes of aluminum you would need, and can perform other full shop services as needed. They are very affordable because they charge based on actual hours spent, not an upfront quote, and the rates are not too high. I have known Terry as a friend/competitor for a decade, and had them also do work for FRC190 when I was a mentor over there. -Paul Ventimiglia |
#117
#118
Great Machine as Always.
Good luck to 254 this weekend. |
#119
Will the build blog for 2014 be released?
#120
Yes! I emailed them and asked them and they replied to me saying the build blog will be posted!
