Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
Unread 06-03-2014, 03:20
Kyle Chan's Avatar
Kyle Chan Kyle Chan is offline
FRC #0368 (Kika Mana)
Kyle Chan is an unknown quantity at this point
Grabbing subsystem data to use in another subsystem in Command Based
Just as the title states, how would I retrieve a variable from one subsystem to implement in another subsystem? For example, if I had a dedicated sensor subsystem, is there any way that I could call a method (which returned the sensor value) from within the sensor subsystem to be used in a method in another subsystem (for example, the collector)?
Unread 06-03-2014, 04:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Grabbing subsystem data to use in another subsystem in Command Based
This is really just a classic C++ question. If a method or member in one class is public any other code (in the same space that has a handle/pointer to the class) can access the member or call the method. In practice it is wiser to keep everything things private and add public methods to access your private data. This way your data (or devices) controlled by the object have only carefully defined external interfaces, making your objects more "coherent".
HTH
Unread 06-03-2014, 07:55
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Keeping with the intent of the Command Based programming approach the only way to accomplish what you are asking is in commands. All commands inherit CommandBase and CommandBase contains static instances of each subsystem. In your command you could get the value of a sensor from your sensor subsystem and then based on it's value call different methods in your collector subsystem. This year we had a DistanceSensor subsystem. It essentially provided the distance we were from the goal in feet via a getDistance method. Our shooter had a setDistance method. In a command called AutoSetShooter we did the following. shooter->setDistance(distanceSensor->getDistance());
Depending on the application it might be better to restructure your subsystems so that the corresponding sensors for your collector are in your collector subsystem. The best example of this is limit switches and pots. They belong in the same subsystem that the actuator is in.
Kyle
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 06-03-2014, 13:26
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Yes, you can access other subsystems to get information; depending on how strictly you want to adhere to the command based approach, this may be 'cheating' a little, but for read only access it doesn't do any harm.
The Robot class has static instances of all subsystems, so you can access them from anywhere that includes Robot.h (just as is done in commands).
The syntax is as follows:
bool ShooterPiston::Fire()
    bool returnValue = false;
    if ((Robot::shooterWheels->IsUpToSpeed() == true) &&
        (Robot::shooterArm->IsOnTarget() == true) &&
        firingSolenoid->Set(DoubleSolenoid::kReverse);
        returnValue = true;
    return returnValue;
Unread 12-03-2014, 14:08
In case anyone is confused, both Kyle and Joe are correct, depending on how you started your project. Currently, if you build your build your project with the Windriver plugins, you get a CommandBase that contains all subsystems. If you use RobotBuilder, the Robot class contains all subsystems.
