Go to Post Are people allowed to go to the roboprom, or just our robots? - AmoryG [more]
Unread 06-03-2014, 11:38
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Be aware of battery and charger inconsistencies!
You can argue however much you want about how it isn't really a rule, but when the LRI tells you that it's not allowed to be used on your robot batteries, you aren't going to win.
Unread 06-03-2014, 11:42
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Originally Posted by sanelss View Post
that's only a recommendation and the safety guidelines aren't really competition rules, they are just that, guidelines. We may not win a safety award but this doesn't seem illegal. Esp considering the chargers state automatic charge current setting with no specification for capacity rating so we believe we are working well within the design constraints of both the battery and charger. Worst case we use a 6A charger for bulk charge then these for top off and consistency guarantee.
Except that the Safety Manual is not just guidelines.
Originally Posted by Safety Manual
This manual applies to anyone involved with the FIRST Robotics Competition including all student team members, Mentors, and support personnel.
The spec sheet for the battery that I linked to in my post above states that the maximum charging rate for these batteries is 5.4A. You will damage you batteries if charge them above this rate.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 06-03-2014, 11:43
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Originally Posted by Steve W View Post
I am sorry to disagree with those that state there is no rule about chargers. It is found in the safety manual and as LRI's we have been told to enforce it. The highlight is mine but a direct quote. From the safety manual:
"Charging and Handling
 Keep the battery-charging area clean and orderly.
 Place your battery charger in an area where cooling air can freely circulate around
the charger. Battery chargers can fail without proper ventilation.
 Do not short out the battery terminals. If metal tools/parts contact the terminals
simultaneously, it will create a direct short circuit. This may cause high heat to
develop in the battery terminal/part/tool area and the battery could explode.
 If a quick disconnect is not available and you must use tools to disconnect the
battery, make sure metal tools don’t contact both terminals at the same time.
Do not charge battery at greater than the manufacturer’s maximum recommended
rate."
We consider the safety manual as guidelines not competition rules. If everything stated in that manual were enforced then every single team would be disqualified for one reason or another. Also the chargers state they automatically set he charge current. Even if they do deliver more than 7A it's not for a very long time either. Worst case is we do bulk charge on old 6A chargers then top off with these. That way they never do get charged higher than 6A but this is just playing around a technicality and more or less on a guideline rather than a competition rule anyway. Either way it won't really be an issue if that's all we have to adhere to.
Unread 06-03-2014, 11:44
FRC #1658
then we'll just play around it. do bulk charge on old 6A and top off with these, win-win?
Unread 06-03-2014, 11:47
Chris_Ely's Avatar
AKA: luckof13
The charger you linked to is meant for car batteries, not FRC batteries. The charger does not know that the battery connected to it is not what it is designed for.
The safety rules are rules, and you will be told to follow them.
Unread 06-03-2014, 11:51
FRC #1658
It's not that we set the charge rate to 15A, the charger states: "automatically selects charge rate from 0 to 15 AMPS to maximize battery life, charge speed and maintenance" it also makes no claims as to a rating of battery it can/can't charge. From other online documentation I found there is no danger at charging up to 1C other than shortening the battery life, which you may consider damage I suppose though. Honestly i'm no worried since we can work around it by bulk charging on 6A then cycling to these for top off
Unread 06-03-2014, 11:53
GearsOfFury's Avatar
GearsOfFury GearsOfFury is offline
Former guy that does stuff
AKA: Mark Anderson
GearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to behold
At the week 1 event I inspected at, our LRI (Al) specifically asked us to look for chargers that operate above 6A, and instructed that they WOULD NOT be allowed, regardless of how you told us you would "program" or use them. OP there is no way for us to enforce that you are following what you are suggesting. I would highly recommend you bring other (i.e. legal) chargers to your event and consider leaving these at home.
Unread 06-03-2014, 11:55
foote stepped in
AKA: E. Foote
FRC #0868
1C for a 40AH car battery is different and bigger than 1C for a 17AH FRC battery.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 06-03-2014, 11:56
FRC #1658
actually it makes no claim as to what types of batteries it can and can't/shouldn't charge. The only indicator is: "automatically selects charge rate from 0 to 15 AMPS to maximize battery life, charge speed and maintenance"
From some online documentation it shows that batteries can be charged faster than manufacturer's recommended rate but it shortens their lifespan, which is fine.
Also from numerous places people are charging all kinds of batteries with these, including FRC batteries. It's a general purpose 12V lead acid battery charger, we are using fairly generic 12V lead acid batteries.
Even so we can easily adhere to the rules by bulk charging on old 6A then cycling to these for the top off
Unread 06-03-2014, 12:10
FRC #1658
there are a lot of things that you can't enforce what a team says they will do other than to take their word for it. As stated we can work within every single rule and planned on it anyway, that doesn't mean that just because something CAN be used in a way that violates the rules that it WILL and that doesn't mean it SHOULDN'T be used just because it might if not used properly. Kind of like the usage of a dremel.
Unread 06-03-2014, 12:12
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
How is "cycling to these for the top off" adhering to the rules? If you can't use them, you can't use them.
Adhering to the rules would mean to use (and only use) LEGAL chargers at ALL times, while at the event. This would mean that the batteries never see the charger you are suggesting.
Save yourself the headache and space by leaving the charger at home when you compete.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 06-03-2014, 12:14
FRC #1658
indeed it is, but battery ratings are in C which is relative to capacity and is more or less identical for each type of battery chemistry unless it was specifically designed a bit differently for some purpose. These are general purpose lead acid batteries, so as far as C ratings go the documentation talking about C ratings for generic lead acid batteries still applies. That's why the documentation does it this way, because it applies to all batteries of that chemistry regardless of capacity.
Unread 06-03-2014, 12:20
It's not that we limit it, it's that they simply aren't sufficiently usable. We have batteries going back a few years and 2012's and back simply don't perform as required
How do you store your batteries during the off season?
Unread 06-03-2014, 12:24
FRC #1658
because there is no distinction to what is and isn't a legal or illegal charger. the rule states "Do not charge battery at greater than the manufacturer’s maximum recommended rate." which we can adhere to by doing bulk charge on 6A chargers then top them off with these where we know for a fact it won't draw even 2A. Just because something can be used it one way doesn't mean it will and so long as we adhere to the rule the usage of such a device is permitted.
Also leaving them at home is not an option. Our older chargers are not acceptable for robot performance. Each one charges the battery differently which is a major problem for us. I'll post on the QA and look for an official response but regardless I believe we can easily adhere to the rules to there shouldn't be any problems.
Unread 06-03-2014, 12:25
Chris_Ely's Avatar
AKA: luckof13
What "automatically selects charge rate" most likely means is that it does what most other "automatic" chargers do: cycles through a factory-set charging algorithm which changes the current and voltage supplied to the battery.
http://batterytender.com/resources/battery-basics.htm/
