Go to Post My strongest FIRST memories, and the teams that leave the biggest impact on me, are teams that seem like they have every reason to give up, but never do. - Chris is me [more]
Unread 06-03-2014, 16:02
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Re: Be aware of battery and charger inconsistencies!
Originally Posted by Jaxom View Post
I'm still not sure how using a >6A charger after you've used some other charger adheres to the rules. But by all means, you should put in a Question on the Q&A to see what the answer is; that's absolutely the right approach. Good luck; I'm pretty sure I know who's going to process that question, and he's the one that tells the LRIs & his inspectors when he's the LRI to tell teams to remove chargers >6A.
because the rules state nothing about chargers, the only rule that mentions anything about charging is the one that states they shouldn't be charged at a higher rating than manufacturer recommends, which is 6A. Using a 6A charger to do bulk charge, then the 15A charger for top off will be within the rules because the charge rate will never be higher than 6A. these new chargers will only top them off which will only draw a few amps at max, so we will be explicitly within what the rule states.
