Go to Post I said it was called FIRST Robotics and the coolest thing I'd seen that day was a 150lb robot balance with another one on a teeter-tooter and and then score basketballs from 30 feet away. - Siri [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 06-03-2014, 18:30
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Were to store practice bot at regional?
Originally Posted by kevin.li.rit View Post
Even if you intended to use the different gearboxes to give your rollers different speeds? Wouldn't this count under the different configuration clause of the robot weight?
For the purpose of inspection, yes, these would count towards the robot's weight. The team in question would need to narrow the field of (30) transmissions down to some number that wouldn't increase their machine's weight outside of the 120lb limit.
Now, if they were to test before they were inspected, and narrow (30) gearboxes down to one, there are no problems here.
As far as getting in the door is concerned, since the (30) transmissions would be unmodified COTS components, they're a non-issue, at least when looking at the withholding allowance.
-Dustin Benedict
