Go to Post The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
  #76   Spotlight this post!
Unread 23-03-2013, 17:20
magic31415 magic31415 is offline
FRC #3950
magic31415 is an unknown quantity at this point
Re: Falcon Scouting System Release
I am still having trouble installing the scouting program. I am using Windows 7 Ultimate and the version of SlimDX that you posted. For some reason it is installing as 2.0.13.43. I am getting this error message after I hit "Install" in the setup for MultipleJoysticks that says "Unable to install or run the application. The application requires that assembly SlimDX version 4.0.13.43 be installed in the Global Assembly Cache (GAC) first." We have been trying to fix this and have already reinstalled Windows on two computers. What should we do?
  #77   Spotlight this post!
Unread 23-03-2013, 23:13
blackwood blackwood is offline
FRC #2359 (RoboLobos)
blackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to behold
We've also had that the GAC issue on several PCs I finally got one PC to do load the programs. I can get the sorter to work, but when I click on MultipleJoysticks, which I assume is the program to run the scouting program, I get nothing. A window opens up that says "verifying application requirements, this may take a few minutes" and that is it, nothing else, when I click on the sorter program, I get a screen similar to what you show in your screenshot, but nothing for the scouting program. Any help would be greatly appreciated! Thanks for all your hard work.
  #78   Spotlight this post!
Unread 24-03-2013, 03:21
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
Have you guys deleted and re installed everything? Also, make sure to extract all the files from the rar folder int your desktop or anywhere else
  #79   Spotlight this post!
Unread 24-03-2013, 09:59
FRC #3950
Yes I have done all of this on a fresh copy of windows. I got the program to work fully on our driver station computer running windows 7 home premium, but we need that for driving. Do you think there is something about windows 7 ultimate that causes this problem?
  #80   Spotlight this post!
Unread 24-03-2013, 15:22
College Student
I have not tested with windows 7 ultimate but this might be the case. Try it on another windows 7 home premium and see if it works.
  #81   Spotlight this post!
Unread 04-05-2013, 10:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Sergio--Do you have scouting data from the Galileo division at Championships? If so, would you mind posting it here?
  #82   Spotlight this post!
Unread 04-05-2013, 18:17
College Student
Yes but some of it is unreliable due to human error (Some matches were not saved properly and some zeros are placed where they shouldn't be). I can still post what I have.
Team 842 Falcon Robotics: 2011-2015 (President, Head Programmer, Drive Team)
Arizona Regional Winners: 2012-2014 (Thanks 610, 1212, 1726, 3944, 2486, 2403)
Curie Division Semi-Finalists: 2014 (Thanks 1311, 2013, 2928)
Las Vegas Semi-Finalists: 2015 (Thanks 3495, 4415)
Curie Division Quarter-Finalists: 2015 (Thanks 107, 228, 649)
2015 - 2016: Programming, Drive Team, and Strategy Mentor for Team 3187, The Titans
Studying Computer Science- Software Engineering at ASU (Class of 2019)
  #83   Spotlight this post!
Unread 06-03-2014, 23:02
!42!42! !42!42! is offline
FRC #4593
!42!42! is an unknown quantity at this point
is there no 2014 update? just curios it seemed to be a very good scouting system.
  #84   Spotlight this post!
Unread 06-03-2014, 23:32
College Student
There is. I am having some last tweeks made on it then I will release it.
  #85   Spotlight this post!
Unread 13-03-2014, 20:56
robotsRcool robotsRcool is offline
robotsRcool is an unknown quantity at this point
Almost done tweaking the system?
[IMG] code is Off
