Go to Post My suggestion is to first focus in on your drive base. Get it running, and drive it into the ground and see what breaks. Then fix it. Rinse wash and repeat. - Andy A. [more]
Unread 06-03-2014, 22:22
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Labview disabled compressor runs *AT REGIONAL IN MATCH 1 TOMMOROW*
Hi CD,
Our team is running into an interesting issue. Our compressor is somehow able to run even when our robot is disabled.
We think that something we're doing is uncovering a bug in the FRC framework, but we don't really know.
We're in match #1 tommorrow and if we don't fix this issue we have to go out without a compressor. We can score auton but then we will run out of air.
Any ideas, CD?
Unread 06-03-2014, 22:30
Re: Labview disabled compressor runs *AT REGIONAL IN MATCH 1 TOMMOROW*
This is usually due to a faulty digital sidecar. Try opening it up and cleaning out any metal shavings, try replacing it if that doesn't fix the problem.
Unread 06-03-2014, 22:35
couvillion couvillion is offline
FRC #1818
couvillion is an unknown quantity at this point
Absolutely sure that it is wired up correctly?
Try to control it programmatically, if you can't make it turn on and off with a button push in tele-op, then the framework can't either.
ShadathChow's Avatar
ShadathChow ShadathChow is offline
AKA: Shadath Chowdhury
FRC #3175 (Knight Vision)
ShadathChow is an unknown quantity at this point
Originally Posted by Arpan View Post
Hi CD,
Any ideas, CD?
Yeah We had the exact problem last week man. It turned out to be the Crio. I would first check the relay ports on the SPIKE and change out the SPIKE if needed. I hope this helps
Unread 06-03-2014, 22:42
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Can you throw some more air tanks on for a quick fix?
Unread 07-03-2014, 01:02
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
We had this same issue as well and it did turn out to be the digital sidecar.
Talk to the CSA at your event and try to get a loaner digital sidecar (assuming you don't have a spare).
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 07-03-2014, 01:07
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
What is a CSA?
I can't figure out the acronym.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 07-03-2014, 01:18
Originally Posted by orangemoore View Post
What is a CSA?
Control System Advisor. Usually found wearing an orange hat that says "Control System Advisor" and a volunteer shirt and badge, probably helping some team that is having control system problems. (Or standing around to help out the FTA and FTAA, if no teams are having issues.)
Unread 07-03-2014, 06:44
Olin class of 2019
Thanks all,
We did our own research last night and it turns out that there is a certain line on the digital sidecar that controls the enable/disable to relays 1-4. We're going to see if we can switch to 5 and 6 (we have 2 relays) for the first match and failing that we will swap the sidecar. Luckily, we already had to swap a sidecar yesterday to fix an electronics isolation issue so everything is really well labeled.
I'll let you know how it goes.
Unread 09-03-2014, 14:00
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
I was at the MI Kettering District event and talked to their CSA, Andrew from NI. He showed me the tool NI has implemented for contacting the CSA's at your event. It is a web based tool that can be used from any smartphone. They may also have a laptop setup at Pit Admin for submitting requests.
http://www.NIParkway.com
He is hoping that more teams will use this tool to make requests and the CSA's will use it to document what was done to solve the issue. This will help identify any trends and possible solutions.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 09-03-2014, 14:39
AKA: Roger Moore
Thanks for the information
Stronghold
Student 2013-2016
Unread 09-03-2014, 19:42
Olin class of 2019
Sorry that OP didn't deliver, was at regional.
Was a faulty DSC. We managed to switch in a new one before our first match friday!
Unread 10-03-2014, 00:47
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
At San Diego we had this set up on a laptop in the Inspection area. This way Inspectors could refer a team to a CSA very easily and faster than we could usually track them down. Just enter your team number and a brief description of the problem and a CSA would show up at your Pit, usually within 20 minutes or so.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 02-04-2014, 16:01
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Team 3940 ran into this problem on our practice robot here in our shop today. We replaced the Digital Side Car to solve this issue. Upon inspection of the faulty DSC, we found a large amount of shavings and metal dust inside the case.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 02-04-2014, 19:53
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Without swapping out the whole DSC, you should try moving to another channel, or just cleaning out the digital IO rail.
The reason the compressor is running is because the digital IO pressure switch is being shorted to ground.
Also this is dependant upon where you start your compressor code from. If you start the compressor call in robot init, it has the potential to run during disabled.
If you start the code somewhere else, it won't run in disabled, unless you ran through that portion of the code first.
We typically only start our compressor in telopInit (to avoid it running during auto and just being an extra electrical load we don't want. (We run the robot in queue to pre-charge our air system)).
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
