#121
Re: Were to store practice bot at regional?
So when you read the rule, what you see is "unlimited COTS items and raw material, unless you plan to use those items on your robot."?
#122
My understanding of the hypothetical versaplanetary problem is as follows.
1) Are the gearboxes pre-assembled? If yes, they are modified, in a way that is intended to be for the robot in question, and should count towards the 45 pounds. If not, or if they are disassembled back to original condition, they are COTS. Even so, "modifying" a gearbox by putting it together isn't something I as your competitor would grouse about, unless... 2) they are intended to be swapped out interchangeably to modify the performance of the robot, especially from round to round, based on the desired function per each round's competitive requirements. If so, you are treating them the same way other teams might treat interchangeable appendages. In this case, they should all definitely count towards your 45, and I WOULD grouse about it. |
#123
1) I think you're pretty safe in your understanding, since this very example is used in the manual when discussing fabricated parts and COTS items.
![]() 2) And if this is the case, ALL of the interchangeable gearboxes need to be weighed with your robot and total 120 lbs or less. In which case you don't need to be re-inspected when you change them from round to round. This having nothing to do with them being COTS or not, of course. |
#124
Wait, you mean like I could do if I merely had a list of parts off my practice bot that was sitting in the trailer? Hmm... |
#126
FRC Q&A 396:
https://frc-qa.usfirst.org/Question/...-long-as-we-do Quote:
#127
This is to keep teams with 2-day events from having an advantage by being able to add 45 lbs to the bag during their access period and bringing another 45 lbs to competition, giving them an effective 90 lbs of withholding. |
#129
So from what I'm gathering, according to the definition of "static", it's okay to have in mind what you need to pull from your practice bot by the event, but you can't decide to pull your arm beforehand, but then pull your intake during the middle of competition? Or is it just saying that the Robot Access period is a disjointed part of the event, and for teams going to a district competition, the withheld set of items can't change between the access period and the friday of competition?
#130
Again, the fact that they're mentioning "a set of withheld parts that cannot change during a competition" seems to clearly imply that you must know before the competition which parts are in that set. If you bring a whole practice bot, and only happen to take off 45lbs of parts but could not have, if asked, said what those parts would be at the outset, then you clearly weren't working with a "set of withheld parts" that weighed under 45lbs at the outset.
#132
Q. Can we bring an old robot to the competition for the purposes of using it to supplement our Chairman's Award presentation and not have the weight count against our team's 45 lb withholding allowance?
Follow FRC0340 on 2014-02-25 | 1 Followers A. These items would count towards the 45 lb limit in R18. I think this pretty much solves the problem. If the GDC counts a old robot against the 45 pound with holding, they would consider a new robot the same way. So now lets stop and go play Aerial Assist ![]() |
#133
By this logic any robot built for demo purposes that a host team may want to have outside to interact with students would count against their weight. What if for part of my RCA I want to bring my FTC team's robot for display in my pit? |
#134
