Go to Post One of those things I learned in kindergarten - never introduce myself to an “enraged” woman wielding a clipboard. - Mark McLeod [more]
Unread 28-02-2014, 13:13
spyla spyla is offline
FRC #3616 (Phenomena)
spyla is an unknown quantity at this point
Active Goal detection - on cRIO or Drive station
Hi,
we are using labview.
for the active goal detection should I do Vision part it in autonomous part of the cRIO Code or should I do on drive station and just send the active status to cRIO? During autonomous stage will drive station interact with the robot?
spyla
Team 3616
Unread 28-02-2014, 13:15
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Active Goal detection - on cRIO or Drive station
The best practice is to do all of the processing on the crio, you want to transmit as little data as possible and keep everthing local on the crio for closer to real time analysis.
Unread 28-02-2014, 13:19
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Plus, for the autonomous hot goal detection, you only really have to process a picture once near the start. If the indicator isn't on the side you're lookign at, your side will be hot for the 5-10 sec period.
(Note: this can become more complicated and require additional logic depending on how and where you line up and what your camera can see)
Unread 28-02-2014, 17:21
Communication from the Dashboard program to the cRIO is not blocked during autonomous mode. You will be able to do vision processing on the computer running the Driver Station and send the "hot or not" status to the robot, if you wish.
Unread 28-02-2014, 17:22
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
I beg to differ, Processing on the cRIO drags it down, and sometimes will create 'lag' as it processes it.
You're already sending your webcam image to the dashboard. Why not process that? Retrieve whatever goal info you need, and send a string back to the robot.
All we're sending back is a Boolean if the goal we're looking at is hot or not.
Unread 02-03-2014, 09:01
The tutorial and example code attempted to show how both approaches can be made to work.
You will not bog down the cRIO unless you send it more pixels/second than it can process. How many that is depends on how you decide to process, image size, framerate, etc.
The processor on your laptop is more powerful, but can pretty easily be overwhelmed by image processing too. Also be careful not to request more images than you are processing or this can introduce video lag.
Greg McKaskle
Unread 06-03-2014, 05:06
ykarkason ykarkason is offline
21st Century Schizoid Man
FRC #3316 (D-Bug)
Team Role: CAD
ykarkason will become famous soon enoughykarkason will become famous soon enough
You will not bog down the cRIO of you won't try real-time processing.
Our vision system relied on processing the targets on-demand, and extracting the useful data out of it.
During auton we ran the processing a max of 3 times, based on if the program didn't land into an error. And that's it - distance, angle, hot-or-not, once, and you're done for auton.
Unread 07-03-2014, 10:16
Alpharex Alpharex is offline
FRC #3293 (Otterbots)
Alpharex will become famous soon enough
I can send you our code to look at if you want to use it or get an idea about how to do it. we process the dashboard image and then send a true(or false) to the Crio. This is method recommended by National Instruments
Unread 07-03-2014, 23:00
JM033's Avatar
JM033 JM033 is offline
AKA: J
FRC #0240 (Tempest)
JM033 is an unknown quantity at this point
use the dashboard and send the data to crio, or else do it on the crio and suffer from super high latency
Unread 07-03-2014, 23:38
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
thats simply not true. you just cant process in large resolutions and 30 fps
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 07-03-2014, 23:54
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
I recommend a third option: Do vision processing on neither on the cRIO or driver station.
Unread 08-03-2014, 00:26
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
We've done both, and doing it on the driver station has been both easier and more effective this year over when we tried it on the Rio.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
