Go to Post Several West Coast teams have attended IRI. I don't know of a single team from east of the Rockies that has attended ANY West Coast off-season. So who is afraid of who? - ChrisH [more]
Unread 07-03-2014, 12:44
Nyle's Avatar
Nyle Nyle is offline
FRC #0422 (The Mech Tech Dragons)
Nyle is just really niceNyle is just really niceNyle is just really niceNyle is just really nice
Mounting VersaWheels
Our team has decided to switch our drive-train over to using 4" Versa Wheel DTs. We will mount the wheels using 1/2" Hex VersaHubs, but are unsure whether a hub is required on each side of the wheel, or whether one hub per wheel is enough.
Unread 07-03-2014, 12:50
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: Mounting VersaWheels
One hub is enough, but I recommend placing a bearing on the other side of the wheel; as opposed to leaving it "empty".
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 07-03-2014, 13:01
Nyle's Avatar
Thanks for the quick response!
Unread 07-03-2014, 13:31
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I've done this before and it works just fine.
An alternative is to use this guy: http://www.andymark.com/product-p/am-1305.htm which makes wheel swaps a tad bit easier since the hex doesn't move.
-Dustin Benedict
Unread 07-03-2014, 13:56
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
We are doing that this year. One bearing on the inside and the hub on the outside. No issues yet with the exception of making it a little harder to get them on the shaft which isn't a big deal.
Another alternative would be to 3D print a hex spacer similar to the linked one if you have access to one.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 08-03-2014, 00:13
Nyle's Avatar
I’ll try that if I have time with all the other stuff that needs to get done. Can’t hurt to be a little bit lighter.
Unread 08-03-2014, 01:22
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
This thing is wonderful. I didn't know it existed.
My comments do not reflect the views of associated teams.
