Go to Post "Professionalism at all times... even when you're playing an epic prank on your friends." - JVN [more]
Unread 07-03-2014, 09:48
Rochester2909 Rochester2909 is offline
FRC #2909
Rochester2909 can only hope to improve
Phnumatics
Our team is having trouble controlling the pressure on our return; we have two actuators and when we release the air our system just falls , any advice?
Unread 07-03-2014, 09:50
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Phnumatics
Place a flow control on your cylinder on the retracting side of the mechanism.
We like these: Part number SMC - AS2052F-07
Just cut the tubing on the proper side of the cylinder and insert this, dial it down to the level you want and you're good to go.
Edit: you also could have ordered some from FIRST Choice that screw directly into the cylinder. I'm guessing that since you aren't already using them, you probably didn't order them. Try asking local teams or checking with local industrial supply shops. The one that most teams have on hand is pictured in the bottom left here.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-03-2014, 09:52
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Phnumatics
Could you describe what you system looks like, and what it is doing in a little more detail? It is a bit had to understand what exactly is happening.
BTW, pneumatics.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
jmartin is on a distinguished road
Re: Phnumatics
Could you clarify what you mean by "our system just falls"? Do you mean that that actuators provide little resistance and they retract because of gravity?
Pictures might help, if you have them.
Unread 07-03-2014, 09:53
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Phnumatics
Describing more of your pneumatic system, with pictures will help more. Be more specific with the term "falling"
What are you trying to control with the actuators?
What is the stroke and bore on your cylinders?
Are you using Single or Double Solenoids?
Are you using flow control/bleed valves on your actuators?
Unread 07-03-2014, 09:55
FRC #2909
Re: Phnumatics
Is there any way we could order this part from Andy Mark?
Unread 07-03-2014, 09:56
cgmv123's Avatar
AKA: Max Vrany
Re: Phnumatics
Yes.
http://www.andymark.com/product-p/am-2032.htm
Unread 07-03-2014, 09:57
Chris_Ely's Avatar
AKA: luckof13
Re: Phnumatics
Flow Control elbow
Flow Control in-line
Unread 07-03-2014, 09:58
FRC #2909
Re: Phnumatics
Yes our actuators just fall due to gravity if there is anyway you know how to control that that would be great!
We have to 8" pull 1'' bore actuators with both acting on single solenoids
Unread 07-03-2014, 10:03
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Re: Phnumatics
Originally Posted by luckof13 View Post
Just be aware that the flow control elbows from Andymark are bi-directional. They will slow down your cylinders going up, as well as going down. If you have problems with cylinders moving to fast in one direction, a better approach is to use a meter out flow control valve on the exhaust side of the cylinder. This slows the air leaving the cylinder (but only when moving in that direction) and a controlled drop. Just be sure to install them in the correct orientation (they usually have arrows to indicate the unrestricted flow direction). Restricting the air coming into the cylinder can sometimes lead to jerky motion.
Unread 07-03-2014, 10:17
FRC #2909
Re: Phnumatics
were already using them, and were still getting to much exhaust
Unread 07-03-2014, 10:18
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Phnumatics
[IMG]I:\POE[/IMG]
were already using them.
You'll need to either attach any images (if under 2MB), or upload them to some image host site.
Unread 07-03-2014, 12:31
Re: Phnumatics
Then you need to adjust them or replace them, you can close the valves completely and let no air pass through at all on several of the types listed.
Andrew Basse
Unread 07-03-2014, 19:42
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: Phnumatics
If your cylinders are retracting due to gravity (and I am assuming a loss of air pressure), you may not have enough storage. How many/what size air tanks do you have? Are they on the high pressure side or the working pressure side? Have you done thorough leak checks and how quickly does your pressure drop?
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
