Go to Post I want to take a moment to thank every single FIRST mentor on behalf of all the FIRSTers (students) out there, for giving us the best we can get. - Arefin Bari [more]
Unread 07-03-2014, 20:33
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Re: Consistent shooter
Originally Posted by MysterE View Post
So, how would one add consistency in ball placement to a catapult based system?
Make sure the ball is sitting in the exact same position every time. Any discrepancies will cause variation in flight path. Engineer the catapult so it cradles the ball better.
EDIT: We actually added a bar to the back of the catapult to somewhat simulate a curved shooter to hold the ball better.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 07-03-2014, 21:44
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
We've been nailing 10pt shots from around the 18ft mark consistently with a spring launcher. Battery drain only effects our reload time. What kind of data are you looking for, specifically?
Unread 08-03-2014, 09:56
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
and near the bottom of the list would be a) motor-powered kickers and b) motor-powered wheel shooters.
The sample size for wheeled shooters seems to be pretty small this year. We have a wheeled shooter consisting of 2 8" Colson wheels in a vertical orientation, shooting from fairly low. Each has independent closed-loop pwm control, to make sure the speed is consistent no matter the battery state (on the practice field we are making the same auto shot for a battery just used in a match as a fresh one). Also having the wheels above and below the ball lets us control the amount of back/top spin the ball has (currently tuned for backspin, although the effects of top spin on the ball trajectory are interesting and not quite intuitive - I am fairly confident we could increase our sweet spot range with top spin, but only the longest shot distance would improve. We have only done enough testing to demonstrate the spin effects I calculated, but not enough to justify a change.)
So far in our 1st day of qualifying matches we are 8/10 in auto mode (shooting from behind the white line), and have the 2nd highest cumulative auto score in our district (2nd to a 2-ball auto, but not by a lot). The 2 misses could likely be attributed to human error, as auto wheel speed was being read from an analog knob on the drivers station, now it's a set calibrated value.
Scoring high in teleop has not been as consistent as auto, but I am confident that will improve with more driver practice. We will see how things pan out in day 2 of this district, and at our second district in 2 weeks.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 08-03-2014, 10:07
What about ball inflation?
Have you tried making the exact same shot with a slightly overinflated ball and a slightly underinflated one?
Unread 08-03-2014, 10:09
We have only done enough testing to demonstrate the spin effects I calculated...
Could you explain what calculations you did, and what testing you did to confirm those calculations?
Unread 08-03-2014, 12:08
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Originally Posted by dodar View Post
I dont think 1114 is a wheeled shooter.
And to what would you base this assumption?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 08-03-2014, 12:56
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
On that when you watch them in their matches it looks like they have a pneumatic puncher.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 08-03-2014, 15:56
Gregor's Avatar
<Since 2011
Unread 08-03-2014, 15:57
dodar's Avatar
That definitely looks like a gatherer to me.
Unread 08-03-2014, 16:00
Gregor's Avatar
The red and white roller is their intake. I wonder what the two black wheels do...
<Since 2011
Unread 08-03-2014, 16:02
NickTosta NickTosta is offline
Team 195 Alumni &amp; Former Driver
no team (The Cyber Knights)
NickTosta is an unknown quantity at this point
(image)
I see two pneumatic cylinders directly behind the ball. Granted, it's hard to say exactly what they're for, but they appear to be positioned correctly to "punch" the ball.
edit: To be honest, it looks like those small cylinders punch the ball into the black rollers. So, it's probably both.
Current college student (electrical/computer engineering), former base driver for Team 195
2011 (36-10): WPI Champions, CT Champions, Galileo 13th seed & quarterfinalists
2012 (26-15-2): NYC Finalists, CT Champions, Archimedes 7th seed & quarterfinalists
Unread 08-03-2014, 17:19
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
We talked to them, it's a combination of wheeled and pneumatic but a the majority of the work is done by the wheels.
2016: FRC 865 Mentor
Unread 08-03-2014, 21:27
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Alright, lets get this thread back on track....
I agree with Ether's original rough sorting of shooter types. Additionally, waiting for the ball to settle in your shooter varies by design (SS style being the best I've seen) and effects your in game shot percentage by giving defences extra time to close in.
For teams using surgical tubing, what have you done to improve consistency? I built a surgical tubing catapult in 2008 and it was never exactly the same between matches. This didn't matter much when throwing a ball over a bar. Does the variation come into play when aiming for a goal?
Queen's Applied Science '13, Applied Mathematics
Unread 08-03-2014, 22:47
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
We were shooting from 8-11 feet not very accurately with a motor driven catapult at 100% power today we I bagged for our slotted time we are allowed and lowers the speed to 84% and now we are shooting at about 98% from three feet off the wall( just behind the low goal) we use 100% speed to shoot over truss
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 08-03-2014, 23:04
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
Our team didn't end up using surgical tubing but I had thought up a way early in the season to ensure consistency between matches with surgical tubing.
If you wind up the surgical tubing on two drums, then unwind it just enough to attach it to the plunger or whatever it was propelling, you could then add a load sensor to the surgical tubing or the motor such that it measured the amount of tension in the tubing. Using two motors (Bag motors would would fine for this) you can have software that causes the drums the tubing is wound on to tighten or loosen the tubing depending on how far you want to shoot and how much the tubing has stretched. This keeps the tubing at the same tension for every match and also allows for lower powers settings in order to pass or shoot from a different distance.
It's not done until it's overdone!
