Go to Post If you think it is such an outrage, then be a do-er and not a talk-er. - BrianBSL [more]
Unread 08-03-2014, 10:35
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
How can an alliance score go backwards during game play?
Check out this video of quarter final match at IE...
https://www.youtube.com/watch?v=y_HR...e_gdata_player
3:21 Red Alliance goes from 40 to 30 points when the truss shot is made
4:19 Red Alliance goes from 90 to 80 points for no reason
How can a score go backwards during a match?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 08-03-2014, 10:54
Re: How can an alliance score go backwards during game play?
Scorekeeper corrections. The correct auto score is 30 (3x move + 1 High not hot). The fact that this gets corrected right as a red robot shoots one of the auto balls over the truss (not worth truss points) is coincidence.
In the second instance you can see the score go from 80 to 90 when a ball is placed in the low goal. The ref must have entered it as a high goal. Around the time you indicated the score goes from 90 to 80 as the high goal is removed, then to 81 as the low goal is added.
Unread 08-03-2014, 11:17
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Thank you, I knew there must be a rational explanation.
