Go to Post FIRST is about the relationships you build. ONE individual at a time. - xitaqua [more]
Unread 08-03-2014, 17:30
boastj boastj is offline
FRC #4495
boastj is an unknown quantity at this point
Exclamation Help us please!
We have created our main.VI project. We came back to it today and it no longer runs the robot it just goes to simulation mode, how do I change this so that when we run the VI it does not go to FRC simulation viewer?
Unread 08-03-2014, 17:36
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Help us please!
Down in the lower left corner of your Robot Main.vi, you will see a status bar with the title of your project in it. Right click on this bar and select the one ending with "RT CompactRIO Target". Give it a minute to reload all the correct vi's and you should be good to go.
I'm right 90% of the time, so why worry about the other 3%?
Unread 08-03-2014, 18:29
Re: Help us please!
When you opened it today, did you open it by opening the project or did you just open Robot Main.vi? You should make sure to open the .lvproj file to get everything loaded up with the right targets.
If you were already doing this then follow what Alex posted above to get your Robot Main pointed back at the correct target.
