Re: Recharging Robot Pneumatics with Air Tool compressor
Originally Posted by Bochek
While I acknowledge that it is illegal to use a shop compressor to fill the pneumatics tanks for a competition match, I fail to find anywhere in the manual that states you can not bring a compressor, and use it in the pits or to fill your robots tanks for use on the practice field.
Please correct me quoting a rule from the manual if I am incorrect.
Here is the full rule which I believe answers your question.
R80
Off-board compressors are permitted, however the compressor must be controlled and powered by the ROBOT.
(Blue Box)
The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in storage tanks on the ROBOT
The intent of this rule is to permit teams to take advantage of the weight savings associated with keeping the compressor off-board. However, using the compressor off-board of the ROBOT does NOT permit non-compliance with any other applicable rules.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
