Go to Post Coming soon to an Earth near you; an Australian team (or 2). Stay tuned. - Elgin Clock [more]
Unread 08-03-2014, 10:15
astro70's Avatar
astro70 astro70 is offline
Columbus Space Program
AKA: Luther Richardson
FRC #4188 (Blue Devil Robotics)
astro70 will become famous soon enoughastro70 will become famous soon enough
Recharging Robot Pneumatics with Air Tool compressor
Has anyone used a compressor like those used with air tools to recharge robots in the pit? It could be connected with a quick release fitting to the pressure vent of the robot.
Luther Richardson, Physics teacher & Coach
Team 4188
2015 Peachtree Winner
2012 Peachtree Rookie All-Star
http://www.columbus2space.org
Unread 08-03-2014, 10:21
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
jmartin is on a distinguished road
Re: Recharging Robot Pneumatics with Air Tool compressor
Pretty sure this is not legal, see rule R79 and R80:
R79
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate.
R80
Off-board compressors are permitted, however the compressor must be controlled and powered by the ROBOT.
Unread 08-03-2014, 10:25
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Not legal on the competition field. If you're practicing/testing, it's kind of a gray area, but I'd still avoid it.
Unread 08-03-2014, 11:53
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Not legal at the competition on practice field, pits or competition playing field. You will be asked to remove from the pit area.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 08-03-2014, 19:56
DonRotolo's Avatar
Back to humble
FRC #0832
Agreed. Completely not legal at any competition. Leave it home.
Unread 08-03-2014, 20:40
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
While I acknowledge that it is illegal to use a shop compressor to fill the pneumatics tanks for a competition match, I fail to find anywhere in the manual that states you can not bring a compressor, and use it in the pits or to fill your robots tanks for use on the practice field.
Please correct me quoting a rule from the manual if I am incorrect.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 08-03-2014, 20:49
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Here is the full rule which I believe answers your question.
R80
(Blue Box)
The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in storage tanks on the ROBOT
The intent of this rule is to permit teams to take advantage of the weight savings associated with keeping the compressor off-board. However, using the compressor off-board of the ROBOT does NOT permit non-compliance with any other applicable rules.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 08-03-2014, 20:50
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Or more importantly, to blow off the robot before powering it up because your team, or the team in the next pt was cutting, grinding, filing, chopping, de-burring, trimming, stripping, or otherwise performing an activity likely to cause metal bits and pieces to be in the air and possibly land in or on your sensitive electronics.
They don't make you wear safety glasses for nothing.
Former Mentor Team 1771
Former mentor Team 4509
Unread 08-03-2014, 20:51
If a team brings a shop compressor, and is using it for tools and the like, and doing that in a safe manner, I have no issue with that.
Once you start using it to charge your robot's tanks, that's where the inspectors run into problems.
Unread 08-03-2014, 20:54
Bochek's Avatar
AKA: Adam Bochek
The rule doesn't state that "shop compressors" are not allowed in the pits. Also filling your robots air tanks from a shop compressor for some time on the practice field would not fall under "non-compliance with any other applicable rules" from what I understand.
Unread 08-03-2014, 20:58
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
R79 has your answer. There is no difference between the competition rules for the competition field or practice field in terms of the robot operation. You can modify your robot and test, but you cannot modify procedures in relation to the safety of operation.
R79
Unread 08-03-2014, 20:59
AKA: Roger Moore
This would be an applicable rule
R79
If you were to use a shop compressor, you would 1) be using an illegal compressor, or 2) you would be using more than one compressor which is also illegal.
Stronghold
Student 2013-2016
Unread 08-03-2014, 21:11
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Please don't use compressed air to to blow off your robot in an FRC pit. As you said yourself, it can send small metal bits into the air. After which they will land in places you cannot control. Maybe in your robot's electrical system, maybe in another team's. You should be using a vacuum, not a blower, to remove small debris from your robot.
See also this post by Dave Lavery several years ago.
Richard Wallace
since 2003
Unread 09-03-2014, 00:58
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
I agree -- I don't know of a rule that prohibits shop compressors in the pits. However, using one to fill your ROBOT's tanks, for any reason, would violate a number of rules -- airflow, one and only one compressor, and control of the compressor by the CRIO. I don't understand why anyone would think that a robot isn't a ROBOT just because it's not on the competition field.
As for the "I don't see any rule that says you can't" justification -- I don't see anything that says I can't use depleted uranium for ballast on my robot.
Mentor http://www.teamtitanium.org/
Unread 09-03-2014, 01:24
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
There are multiple issues with having shop compressors in the pits.
First, as inspectors we don't know what you're using it for. You could use it to charge your robot at any point - while this is clearly not legal for competition use, doing so for use on the practice field and in the pits also bypasses half the safety mechanisms on the robot - stored air is not under the control of the robot, it doesn't turn off when the robot is disabled or e-stopped, and it doesn't automatically stop at 120 PSI (many shop compressors can be adjusted to charge to greater than 120 PSI). So using it to charge the robot for non-competition uses at a match violates R8 by creating a potentially unsafe condition in the pits or practice field.
Second, many of the venues we run our competitions have limited available power. Shop compressors require significant startup current and could easily blow a breaker, cutting power to your pit and your neighbors.
Third, as already pointed out, shop compressors can very easily be used to create a dangerous situation by blowing metal chips around - those can easily find their way around safety glasses and into team's electronics.
Please, do us all a favor and leave the shop compressors in the shop. We don't want to see them at competition.
2016: Lake Superior WFFA
