Go to Post ...there's nothing worse than a problem you can't solve because you don't even know about it. - Dave Flowerday [more]
Unread 08-03-2014, 20:58
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: Recharging Robot Pneumatics with Air Tool compressor
Originally Posted by Bochek View Post
While I acknowledge that it is illegal to use a shop compressor to fill the pneumatics tanks for a competition match, I fail to find anywhere in the manual that states you can not bring a compressor, and use it in the pits or to fill your robots tanks for use on the practice field.
Please correct me quoting a rule from the manual if I am incorrect.
R79 has your answer. There is no difference between the competition rules for the competition field or practice field in terms of the robot operation. You can modify your robot and test, but you cannot modify procedures in relation to the safety of operation.
R79
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate.
