Go to Post CD is not the GDC. (Otherwise we'd be better at getting the game hints! ;) ) - Ninja_Bait [more]
Unread 08-03-2014, 20:34
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Possible FMS problems.
Our team competed at the Arkansas Regional and we ran practice matches all Thursday, no problems at all. There was no score keeping during these matches and we did good. During our first qualification match we ran great until the last 15 seconds we lost power to the C-Rio, and all Comm. and Code. During the next match our battery fell out. And in every other qualification match we would run, then our C-Rio would reboot. Sometimes it would happen when we took hard hits, others we would just drive forward and then reboot. So first we replaced the C-Rio, same problem, all of the wiring was fine, had multiple inspectors confirm that, Then we replaced the PD board, took it to the practice field and it worked fine, we ran at full speed into the low goal multiple times, it was just fine. Then we went onto the field on saturday and same problem happened. We replaced the main breaker, same problem. So then we got picked for elims. and during the time in-between our match, we ran on the practice field with our alliance members at least 20 minutes, just fine. We went out on the field, drove a little bit, and re booted. same thing happened next match. Any ideas what could be the problem?
Unread 08-03-2014, 21:01
M. Lillis's Avatar
M. Lillis M. Lillis is offline
AKA: Michael Lillis
FRC #0177 (Bobcat Robotics)
M. Lillis has a spectacular aura aboutM. Lillis has a spectacular aura about
Re: Possible FMS problems.
Although I don't have any solution or hypothesis for your problem, I did notice something in one of our matches last weekend. The FMS messed up the hot goals (As seen here).
None were hot for the first ~5 seconds, then the left was hot for the last ~5 seconds. But right as the bell rings for teleop to start, the right turns yellow, indicating that it is hot. If you look to the left of the frame, you can tell (watch a few times) that the same thing happened for the blue alliance.
Driver 2012-2014
Official Record: 82-44-0 (1.86 W/L)
2014 Elimination Record: 18-2
2014 CT State Championship Winner
2014 New England District Championship Winner
2014 Hartford District Winner
2014 Granite State District Winner
2013 CT State Championship Winner
2013 Connecticut Semi-Finalist
2012 Connecticut Semi-Finalist
www.BobcatRobotics.org
Unread 08-03-2014, 21:03
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The FMS system this year could definitely use improvement, however it would not cause your robot to reboot. You have a wiring or power distribution problem that you still haven't discovered. They can be tricky!
Unread 08-03-2014, 21:06
FRC #4490
I never saw much of that during our regional, and the inspectors were absolutely great working tirelessly to diagnose the problem, it just seems weird because we replaced the all of the electronics and had the same problem and it was even worse in eliminations even though we didn't take a lot of hits? and we had just been running great? I'm just unsure, not upset, I just want to know what we need to fix.
Unread 08-03-2014, 21:10
FRC #4490
While the C-Rio is rebooting, it isn't the only thing, in several matches the d-link did as well, and it seemed like we would randomly just shut down and not work, and under diagnostics the robot light would be green, not the bridge. I'm just wondering if there could be something in our code having a bad reaction with FMS? I would completely agree it is a power or wiring issue if we hadn't been running perfectly fine any time other than when connected to the field.
Unread 08-03-2014, 21:15
FRC #4490
https://www.facebook.com/photo.php?v...type=2&theater
here is a link to one of the matches we played in. We are the robot with the huge orange net, at around 1:55 in the video, we lost all communication.
Unread 08-03-2014, 21:24
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Did you work with the CSA (Control System Advisor aka "orange hat") at your event? They are experts in robot troubleshooting.
From your description it does sound like a power/wiring problem, possibly a connection to the radio or a short to the frame.
Take a look at the Driver station log viewer for the matches where the problem occurred. Details of how to do this can be found at the WPI screensteps pages
It might also be a good idea to cross post this in the Technical Forums.
Unread 08-03-2014, 21:28
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
^+1 to what Mike said above.
We had a similar issue in one match. Afterwards we found an intermittent short to our frame that had gone undetected during inspection. We fixed that, and never saw the problem again.
Richard Wallace
since 2003
Unread 08-03-2014, 21:30
FRC #4490
Yes we did work with him, he was unsure after we replaced everything, we looked at the logs, definite signs of the C-Rio rebooting, and he also saw the D-Link reboot. The thing that I am confused about is how we can run just fine multiple times when we are off the field, but never work when we are on? I do not know how to cross post? Are you saying to post the same thing in a new thread under technical Forums? Thanks for the feedback guys! I don't mean to try to argue or anything, I just want to figure this out.
Unread 08-03-2014, 21:33
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Do you want to post your logs from the matches where you disconnected?
Unread 08-03-2014, 21:38
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
I suspect an intermittent short somewhere in your system. We had a similar problem today with our practice robot, and that was the issue.
We also had a similar problem last year and could not figure it out. We found several things we thought were causing it, but it just kept happening. I'd be very interested to hear your solution if you find it.
MikeE's Avatar
no team (Volunteer)
In my experience some wiring issues only become a problem in the hardest of hits. These tend to happen in the heat of competition and rarely on the practice field.
You could post your original question in a new thread in the Tech forums and link to this one. It's very likely the underlying issue is an intermittent & tricky problem with the robot so I'd suggest a different title to the thread.
Unread 08-03-2014, 21:39
FRC #4490
I don't have access to them now, but I will definitely post them as soon as I do. In no way am I trying to blame the field, we built the robot, the results are more than likely our fault, I'm just very confused and concerned for for other teams if they run into a problem like this. At first it seemed a power issue, then we made sure everything was good, then we just kept fixing things but it just kept happening, the CSA checked the logs every time showing the same thing. I will try to post those sometime this week.
Unread 08-03-2014, 21:49
FRC #4490
I made a new thread, and again, thanks for the feedback. http://www.chiefdelphi.com/forums/sh...hreadid=127623
Unread 09-03-2014, 00:34
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
When you next get to unbag that comp bot....Look at the Radio Power Converter (there are 4 wires....1 yellow, 2 black center ground wires, and 1 red).
Are the 2 center grounds possibly crossed over? The black nearest the red wire should be paired w/ the red. The black nearest the yellow wire should be paired w/ the yellow.....And the yellow should be connected to the radio power + side (black w/ white stripe wire to the radio).
We had no problems whatsoever w/ that exact type of rebooting issue (you seem to be alluding to), w/ our competition bot, then we put that bot into the bag happy as can be after much practice on the 18th of Feb....That 1 was wired correctly.
Started working w/ our practice bot later, since we had been waiting for a ball P.U. gearbox to arrive, and lo and behold after that was in and running right, we had the same exact "once in a while connection loss issue" that you speak of when testing the practice bot"....Shoot, dry shoot, load a ball (no problems, except a very intermittent loss of connection that got worse, not better). We zip tied the radio power connector, changed radios, checked for a frame grounding issue, we thought we did everything....Then, we noticed a real error in wiring (one of the students wired the radio power converter incorrectly, as the 2 center grounds were crossed over).
When we removed the power converter (holding it w/ wires away from you, wires top, from the left), the order should have been yellow /black-black /red...(Make sure they are paired just like that).
Wired correctly now (;-0), we have never lost connection again no matter what we hit, or do, after many rough hours of practice. (It was simply the 2 blacks crossed over...The black nearest the red was w/ the yellow...and the black nearest the yellow was w/ the red. Those 2 grounds are not created equal by any means on that power converter). Wasn't easy to notice as that converter was in a spot way down under and very hard to see unless you were looking very closely.
The power connector to the d-Link radios are also very famous for intermittent loose connections and subject to wiggling in the socket easily...tape it, zip tie it, etc. (but of course, you cannot solder it...You need to get that radio configured at the events at the kiosk, as you do already know).
Please post back if you find that is the problem please (It may not be, but ours was...and both act the same). And GOOD LUCK in tracking down an electrical gremlin, as they are not always easy.
Edited: BTW, that practice bot electrical board was the 1st 1 wired...(It was the practice board of course).
