Thread Tools |
Rating:
Display Modes |
Re: Need help diagnosing a problem
I posted over at your other thread...Check the Radio Power Converter for a crossed over center ground wires possibility. (black nearest the yellow should be paired w/ the yellow / black nearest the red should be paired w/ the red). We had same issue w/ our practice bot recently...Fixed it only, no more intermittent loss of connection issues now.
We are using a CAN bus and we found that when the voltage drooped the can controller would brown out and die not restarting for the rest of the match. After much tinkering we figured out it was due to the fact that we are running batteries that are up to 5 years old and cant hold a charge to save their lives.
The log file viewer can be launched from the Start menu or the Charts tab, lower right button. Scroll the listbox to the appropriate date, typically the bottom line or near the bottom. The graph will show CPU, battery, comms latency, and comms loss on the majority of the graph. Gaps in the battery with an orange vertical marker on the left and a green vertical marker on the right are a disconnect from the field. It is often useful to change the filter ring above the graph from Default to one of the All settings. Then zoom to the orange/green band and you should see additional yellow markers for the ping results. You can hover your mouse over any marker symbol and the Message box in the lower left will give the text of that message.
There are three common occurrences -- loss of radio and cRIO, loss of only cRIO, and loss of only radio. If there is a yellow vertical marker in-between the orange and green, the hover will likely say that the Radio was lost. This message is the cRIO tattling on the radio. When the cRIO loses its communications protocol during a match, it tries to ping backwards up the chain while the DS pings down the chain. This can help pinpoint where the drop happened. When the cRIO comes back in communications, it gives a post-dated message explaining that it was powered and saw the robot radio go away. If you do not see that marker, look at the first yellow dot near the orange vertical marker. Hover and it should give the ping status of each comms element. It will tell you whether the robot radio was good or bad. What this information can help with is to identify which element rebooted during the match. This tells you which connectors, cables, and wire routes to focus on. Please keep in mind that if both elements rebooted, the problem could be a short or open at the battery terminals, the breaker, or the PD. If you are losing the radio, please verify that it is connected to the 12/5 regulator powered from the 12V boosted circuit on the front of the PD next to the cRIO power port. If you power it from an unboosted 12V along the sides of the PD, they will droop and you will lose the radio during a match. Also do not power the radio from the 5V camera port on the front of the PD. I do not believe it is as protected as the 12V. I know this is a long post, but one more topic. If the robot stops moving, but the Communications and Robot Code LEDs remain lit, the issue is likely at the digital breakout board. Inspect the three LEDs near the RSL connection. If the 5V LED is out, look for debris that is shorting pins or possibly replace. This 5V is for the PWM signals. If the LEDs are good, look at the ribbon cable connectors. Also verify that the digital module is firmly snapped into the cRIO. Greg McKaskle |
Could you post the video somewhere where dinosaurs like me who don't use Facebook can see it?
Sometimes there are visual clues. e.g all the lights dimming on the robot just before a reboot which implies severe voltage drop (old battery/high current drain or sometimes a short). |
We experienced this problem (among many) at the Hub City Regional. It ends up we were stalling motors which drew a lot of current and dropped the voltage at the radio which caused it to reset. It didn't happen on the practice field because it was tethered, but the minute we were driving in a match, the communication dropped. We were frantically rebuilding our drive train so that we could compete. Unfortunately, we got the last bolt in AFTER our last match.
I posted a long answer in the other thread.
#8
Our problem was from our own making. I pointed out that the SLOW speed of our transmission was geared to go 19 feet per second, and that the max at high speed should only be around 15 feet per second. The build team chose not to make the change. I didn't realize that the problem would manifest in the way it did, but I packed the parts to make the change because I knew it was coming. It was a hard lesson to learn, but one they won't make again. I felt bad for our alliances that had to play with only 2 players, but we were pretty much a brick. We have one more regional where I hope we will do better.
On the other hand, it was interesting to note how much luck can affect your final ranking. We ended up 25 out of 42. I lost track of how many rounds we missed, but it had to be more than 4. It just emphasizes how important that scouting data is. We were close enough to the top 24 to be considered by an uninformed team. Although we were running by that time, I advised the team to decline any selection in the unlikely chance it occurred. We just were not reliable enough. |
#9
We have seen defective main (150A) circuit breakers that would open under high vibration, sometimes even popping open/off.
Lightly tapping on the breaker would sometimes replicate the problem. One more thing to add to the check list. |
#10
We did discover something similar to this I believe, we could force a shut off by wiggling one of the connectors, another great catch by our CSA Alan, I have no idea what we would've done without him or people like him, thanks for the advice. Tomorrow we plan on testing all of the connections with a multimeter after some driving, I will post an update on our findings then.
#11
We had a similar problem and it turned out to be a defective power connector to the radio. Check that. It's an easy fix.
