Go to Post Chances are it's an electrical or mechanical problem... - mechanicalbrain [more]
Unread 08-03-2014, 13:52
DaboRoss's Avatar
DaboRoss DaboRoss is offline
User.
FRC #4030 (NullPointerException)
DaboRoss is an unknown quantity at this point
Re: Robot doesn't drive when code is deployed.
This is happening to us, except for it only happens when in game mode, and it stops responding around 10 seconds after autonomous ends. It doesn't happen when just enabling practice-teleop. It's pretty much the exact same error as posted above, which is why I responded to this thread.
Do you think that this error could be caused by the same stuff, even if it works when not in game mode.
~Dabo Ross
Unread 09-03-2014, 08:00
What is game mode?
Pretty much the same errors is probably a different error. Please post your error messages.
If your robot moves in teleop and auto, then it is not an issue with swapped modules -- unless something is swapping them on the robot while code is executing.
Greg McKaskle
Unread 10-03-2014, 11:38
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Originally Posted by swaglord2000 View Post
We actually found our issue! The modules on the cRIO were opposite what they needed to be so when we put them in the right order we were able to get a response.
Did the imaging tool indicate that they were in the correct location before fixing it, though? My team's off-season robot is having unexplainable issues similar to the ones mentioned here in this thread, except the robot shows absolutely no indication of functionality other than printing button states (not axis states) from the controller to the DriverStation. The imaging tool says that all of the modules are green (in the correct location, I assume), and reformatting / re-imaging it doesn't help in the slightest. We've reduced our code down to the absolute minimum, but nothing has worked...
Unread 12-03-2014, 22:33
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Don't assume just because it's green that it's in the right location. Check connections physically please, software fails too (something I hate hearing when we're working on the robot, it's always easy to point the finger at the programmer ), make sure Analog is in port 1, ribbon cable module is in port 2, and solenoid module is in port 3. Can't wait for the roboRIO, when all these problems will vanish and new ones will arise.
