Go to Post However, I do expect something truthful to come out of some of Dave's posts. - Karibou [more]
Unread 09-03-2014, 08:09
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Re: Multi-Choice Autonomous
Originally Posted by Greg McKaskle View Post
Yes, each button has a text field to the right of it. It should store and retrieve those when you next launch the DS. They are stored in the ini file. The names are not sent to the robot, only the Boolean values.
Greg McKaskle
About how much text do you think I could put in each text field?
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 09-03-2014, 08:12
If you have the DS, give it a try. In the first Button, I typed "About this much". It wrapped on the 'h'.
Greg McKaskle
Unread 09-03-2014, 08:14
Greg McKaskle
No, sorry, I don't have the DS in front of me, but I get the picture: I only have space for 2 or 3 keywords.
Unread 18-03-2014, 08:56
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
We are using another method based on the SD. We have a record and replay system that stores the driver & manipulator input to a file on the cRIO. Autonomous reads the selected file and populates the variables that control the robot. The drive team chooses the autonomous to run from our custom dashboard app before the start of the match.
In Begin.vi we populate the array of autonomous choices (custom file extension *.auto) and write it to the SD.
In Dashboard Main.vi we read the array of choices and populate an enum ring's String Property with the file names.
Autonomous then sends back the values it received so we know it got the correct values.
ID:	16591  Click image for larger version
ID:	16592  Click image for larger version
ID:	16593  Click image for larger version
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 19-03-2014, 00:53
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Here's yet another method if you don't like the DS buttons:
Set up a Enum text box on your dashboard and give each number value a corresponding label, showing your driver which program to use.
Write the integer value to a SD variable and then in your autonomous mode, read the value and have a case structure select the correct program to run based simply on the integer value.
When you set up your player station, select the correct program then leave the variable alone. As the match starts, it will read the variable from your dashboard once at the beginning of the Autonomous Period, then execute the correct program.
Our team has used this method for two years and never had an issue. It's reliable and versatile, allowing for many different modes and configurations, as long as your drivers remember to check and make sure it's correct before the match starts XD.
Per Audacia Ad Astra
