Go to Post In this case, "non-thermal protected" would mean "future paper weights." - Rick TYler [more]
Unread 09-03-2014, 12:06
18mfogwell's Avatar
18mfogwell 18mfogwell is offline
AKA: Michelle Fogwell
FRC #4460 (Green MASHine)
18mfogwell is an unknown quantity at this point
Netbeans programming ONE motor on axis of Logitech Attack 3
Hi All!
Our team only knows how to program the axis on the Logitech Attack 3 if we are working with 2 motors. How would we change the program if we were to only program one motor?
Thanks in advance!
Green MASHine 4460
Unread 09-03-2014, 12:22
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Netbeans programming ONE motor on axis of Logitech Attack 3
Motor.setSpeed(joystick.GetRawAxis(1));
Where 1 can be replaced with your joystick axis, joystick can be replaced with your joystick name, and motor with the name of your PWM output.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 09-03-2014, 12:26
18mfogwell's Avatar
Okay, thanks! I will try it!
Unread 09-03-2014, 12:30
18mfogwell's Avatar
So I have
Pulley.setSpeed(operator.getRawAxis(2));
It is coming up as a wrong command saying:
setSpeed(double) is not public in PWM; cannot be accessed from outside package
How do I fix this?
Thanks
Unread 09-03-2014, 12:47
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Whoops, my bad. It's "set" instead of "setSpeed." Try it like that.
EDIT: also, make sure that your pulley is designated as a jaguar, victor, or talon.
Unread 09-03-2014, 12:49
18mfogwell's Avatar
Whoops, my bad. It's "set" instead of setSpeed. Try it like that.
Okay. That works.
Why would the axis numbers vary? I know because of the x and y axis but would the number for the y axis vary?
Thank you
Unread 09-03-2014, 12:54
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Thank you
I'm not quite sure what you mean. Could you please elaborate?
Unread 09-03-2014, 12:57
18mfogwell's Avatar
I'm not quite sure what you mean; could you please elaborate?
What would the number be for the y-axis? Does the number vary?
Unread 09-03-2014, 13:16
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Ah, ok. Every joystick axis has a number attached attached to it. The joystick.Get command basically checks a database for which axis number matches x, y, z, or the other axis names. I prefer to use getRawAxis because I know exactly the axis number I am calling for. It's really a matter of preference. If you prefer, you can use joystick.getAxis(y) to return the same value.
Unread 16-03-2014, 11:12
18mfogwell's Avatar
Is there one numbers that is always associated with x or y?
Unread 16-03-2014, 11:22
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
The x axis is usually 1, and the y axis is usually 2. Axis 3 is usually the throttle, unless there's a twist axis, like in the Extreme 3D Pro joystick.
