Go to Post If you don't KNOW something as fact, please do not state it as fact. - dlavery [more]
Unread 10-03-2014, 11:33
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
Re: Frame Drive
Last year my team integrated our gearboxes into our frame to save space in the middle of our robot for disc movement. We had 1.5"x3"x.125" aluminum tubing, and our drivetrain was west coast style. We took the gears and hardware from a Toughbox and built them into the tube, mounting the CIMs and some bearings to a single plate that was bolted onto the inside of the frame. The design worked and saved space, but we had some efficiency loss because the sides of the frame rail were not perfectly square, and it affected our gear spacing slightly. Also, maintenence was difficult on this design because there was no room to pull the CIMs off of the gearbox- however, this was due to other packaging in the robot, not the gearbox design. IMO if you can package this gearbox with the rest of your robot and you account for tolerance in the walls of the aluminum frame, this could work great.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
