| Thread Tools |
Rating:
Display Modes |
#46
Re: exploding plastic storage tanks
I haven't seen it yet, so I'll reiterate this point: NEVER WORK ON A PRESSURIZED SYSTEM.
Tightening brass fittings in a pressurized plastic tank has a higher probability of causing cracks, which ultimately leads to a rupture. I don't know the details of the GTR tank rupture, but all of the evidence in past explosions points to user error, not a design flaw. |
#47
In a competition designed for high school students where safety is assessed by volunteers whos professional background may have no connection with pressurized gas systems, the barrier between "user error" and hazardous explosions should be pretty darn high. This isn't about getting a refund for busted tanks, it's about preventing injury. If the current scenario has resulted in repeated failures, it's obviously not adequate.
#49
I would argue that user error in play would be utilizing the tanks improperly in an environment that they aren't made for. The problem is, teams see other teams successfully doing it and don't take the time to fully educate themselves on the different protocols necessary to make them safe. If you want to have tanks in an area that risks being hit or needs to be strapped down rigidly, go with metal tanks. Using plastic tanks necessitates finding a location where they will be under minimal load, mounting which will result in no damage, and ideally if one does explode shrapnel will be contained or redirected in a safer direction (i.e. at the ground). Despite maintenance being a chore that is one of the reasons I now prefer putting plastic tanks in our 3x3 1/8" wall drive tubes. In the event of a fracture shrapnel would be stopped by the walls of the tubes and the drive modules at either end. Additionally I make a huge emphasis of informing any of our students who may work on our plastic storage tanks that if it is leaking you are better off removing the fitting and redoing the teflon tape than continuing to tighten it if it is leaking. Last edited by Trent B : 10-03-2014 at 15:23. |
#50
Who suggested that someone should do that?
#51
Take some heavy socks and make tank cozies! At the very least the fabric will help contain the fragments while allowing the air to escape.
#52
You, and someone on 3883 said they covered up their tanks with bumper fabric.
Does anyone happen to know if the Andy Mark white tank that is sold is Clippard, or Pneuaire?
Can someone confirm that the tanks that exploded are only the Clippard brand 'white' threaded version? |
#54
Is Clippard the only maker of plastic tanks? Are the ones from PneuAire also from Clippard, or does PneuAire make their own?. Anyone else?
Are all of the failures so far on Clippard tanks? |
#55
Not to add another reason to not use (or be wary of) plastic air tanks but, has anyone paid attention to the temperatures they're being exposed to, either while in operation or storage?
The published temperature range for the New (2014) Black AVT-PP-35 Tank is 35* F - 100* F (1.5*C - 37.5*C), and I believe (but don't quote me) that the tanks from previous years have the same or at least similar temperature range. I can think of a handful of different ways that tanks could be exposed to conditions outside of that window, which makes me wonder if environmental conditions play some role in the tank ruptures... |
#56
Team 225 has managed to make one of the new black plastic tanks fail, but the failure actually occurred on the push-to-connect fitting, which snapped out under pressure. This might be an intentional design, as losing a hose is probably less dangerous than throwing shrapnel around
#57
Personally I'm for a ban of the plastic tanks. It is not that they are inherently unsafe, but that there are so many ways to unintentionally compromise their safety that are likely to occur when used in FRC.
#59
#60
The PneuAire tanks are distinctly different in design from the Clippard tanks. Unfortunately I don't have a pair handy to take photos of, but I have handled both at the same time this past build season.
