Go to Post DonRotolo used COMMON SENSE. ... ... FIRST/Chief Delphi Community fainted! - PayneTrain [more]
Thread Tools Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
  #46   Spotlight this post!
Unread 10-03-2014, 15:00
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: exploding plastic storage tanks
I haven't seen it yet, so I'll reiterate this point: NEVER WORK ON A PRESSURIZED SYSTEM.
Tightening brass fittings in a pressurized plastic tank has a higher probability of causing cracks, which ultimately leads to a rupture.
I don't know the details of the GTR tank rupture, but all of the evidence in past explosions points to user error, not a design flaw.
  #47   Spotlight this post!
Unread 10-03-2014, 15:04
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
If any of the mentioned failure mechanisms had been applied to a metallic tank would there have been a failure? Or a brittle/catastrophic failure?
  #48   Spotlight this post!
Unread 10-03-2014, 15:10
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
In a competition designed for high school students where safety is assessed by volunteers whos professional background may have no connection with pressurized gas systems, the barrier between "user error" and hazardous explosions should be pretty darn high. This isn't about getting a refund for busted tanks, it's about preventing injury. If the current scenario has resulted in repeated failures, it's obviously not adequate.
  #49   Spotlight this post!
Unread 10-03-2014, 15:17
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Likely a PSA of some sort would be needed, or harsher restrictions in order to prevent future problems. Unfortunately, these tanks are probably perfectly adequate in the other environments where they see a static loading. I recollect Clippard testing tanks last year at several times their advertised maximum pressure without failure in a presumably static low load environment. The environment of FRC is typically anything but static and warrants more care.
I would argue that user error in play would be utilizing the tanks improperly in an environment that they aren't made for. The problem is, teams see other teams successfully doing it and don't take the time to fully educate themselves on the different protocols necessary to make them safe.
If you want to have tanks in an area that risks being hit or needs to be strapped down rigidly, go with metal tanks. Using plastic tanks necessitates finding a location where they will be under minimal load, mounting which will result in no damage, and ideally if one does explode shrapnel will be contained or redirected in a safer direction (i.e. at the ground).
Despite maintenance being a chore that is one of the reasons I now prefer putting plastic tanks in our 3x3 1/8" wall drive tubes. In the event of a fracture shrapnel would be stopped by the walls of the tubes and the drive modules at either end. Additionally I make a huge emphasis of informing any of our students who may work on our plastic storage tanks that if it is leaking you are better off removing the fitting and redoing the teflon tape than continuing to tighten it if it is leaking.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
  #50   Spotlight this post!
Unread 10-03-2014, 15:31
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by mman1506 View Post
Whether a sleeve is an effective solution or not wrapping a piece of bumper fabric around a tank in a bad location and deeming it safe without any proper testing is ignorant.
Who suggested that someone should do that?
  #51   Spotlight this post!
Unread 10-03-2014, 15:32
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Take some heavy socks and make tank cozies! At the very least the fabric will help contain the fragments while allowing the air to escape.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
  #52   Spotlight this post!
Unread 10-03-2014, 15:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
You, and someone on 3883 said they covered up their tanks with bumper fabric.
A spandex sleeve (or even bumper material...) over each tank would be an elegant and easy way to safeguard folks from flying debris, and the porous nature of the fabric would prevent the air pressure from 'exploding' the sleeve.
Hey ANDYMARK! Are you listening?
Originally Posted by FRC3883FRC View Post
Our team had our tanks on our intake a very vulnerable position. We were highly highly HIGHLY recommended by the inspectors (almost to the point of not passing) to cover our tanks. We simply added bumper material over both of the tanks. They still fit right in the same c claps they some with and they dont look all that bad. A couple zip ties and the bumper fabric and we were good to go. You can see in the video that our robot has two red tubes at the top of the intake and around 9 seconds in you can see why they highly recommended covering them up.
Here is the video.
http://www.youtube.com/watch?v=nvAFL...u8USGMhWY2qgkw
If you are using these tanks make some covers or make sure they are in a very safe location.
  #53   Spotlight this post!
Unread 10-03-2014, 15:38
Tom Line's Avatar
Does anyone happen to know if the Andy Mark white tank that is sold is Clippard, or Pneuaire?
Can someone confirm that the tanks that exploded are only the Clippard brand 'white' threaded version?
  #54   Spotlight this post!
Unread 10-03-2014, 15:44
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Is Clippard the only maker of plastic tanks? Are the ones from PneuAire also from Clippard, or does PneuAire make their own?. Anyone else?
Are all of the failures so far on Clippard tanks?
Jim
  #55   Spotlight this post!
Unread 10-03-2014, 15:55
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Not to add another reason to not use (or be wary of) plastic air tanks but, has anyone paid attention to the temperatures they're being exposed to, either while in operation or storage?
The published temperature range for the New (2014) Black AVT-PP-35 Tank is 35* F - 100* F (1.5*C - 37.5*C), and I believe (but don't quote me) that the tanks from previous years have the same or at least similar temperature range.
I can think of a handful of different ways that tanks could be exposed to conditions outside of that window, which makes me wonder if environmental conditions play some role in the tank ruptures...
-Dustin Benedict
  #56   Spotlight this post!
Unread 10-03-2014, 15:57
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Team 225 has managed to make one of the new black plastic tanks fail, but the failure actually occurred on the push-to-connect fitting, which snapped out under pressure. This might be an intentional design, as losing a hose is probably less dangerous than throwing shrapnel around
  #57   Spotlight this post!
Unread 10-03-2014, 16:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
The compressor definitely outputs air warmer than 100F, evidenced by the compressor routinely getting "too hot to touch." I don't know if plastic tanks have ever gotten to that temperature, but the possibility is definitely there.
  #58   Spotlight this post!
Unread 10-03-2014, 16:03
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Personally I'm for a ban of the plastic tanks. It is not that they are inherently unsafe, but that there are so many ways to unintentionally compromise their safety that are likely to occur when used in FRC.
  #59   Spotlight this post!
Unread 10-03-2014, 16:04
Racer26 Racer26 is offline
1310s tank would have definitely seen temperatures (at least briefly) outside of that range, if only when transiting between their school and haul vehicle, and then into the venue. If the haul vehicle sat outside not running anywhere for a while, the tank could have conceivably seen temps in the neighborhood of -20C.
Well, its a failure, but at least its not a catastrophic failure of the part, resulting in explosive decompression and flying shrapnel.
  #60   Spotlight this post!
Unread 10-03-2014, 16:05
College Mentor
AKA: Trent Borman
The PneuAire tanks are distinctly different in design from the Clippard tanks. Unfortunately I don't have a pair handy to take photos of, but I have handled both at the same time this past build season.
