Go to Post Keep your chin up, your safety glasses on, and don't let the magic smoke out of the electrical components and you'll do just fine :) - rsegrest [more]
Unread 10-03-2014, 16:26
Re: Pre-charing pneumatic air tank
Originally Posted by mikets View Post
But would somebody tell me why is my proposed setup not equivalent to the onboard setup? It has the same model pressure switch that will cut off compressor power. It's using the same compressor model and spike as the onboard system. The only difference is the missing cRIO.
There is one more very large difference. Your onboard pneumatics system (with its compressor and pressure switch and everything else) gets checked by the inspectors for proper operation. Your proposed setup does not. Its design might well be equivalent, but the execution does not get evaluated by people responsible for ensuring that every team plays by the rules.
(The more fundamental difference is that your proposed setup won't work. The Spike control input is a 5 volt signal.)
