Go to Post Physics is not a religion. - Jack Jones [more]
Thread Tools Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
  #61   Spotlight this post!
Unread 10-03-2014, 16:16
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: exploding plastic storage tanks
Originally Posted by Wren Hensgen View Post
Team 225 has managed to make one of the new black plastic tanks fail, but the failure actually occurred on the push-to-connect fitting, which snapped out under pressure. This might be an intentional design, as losing a hose is probably less dangerous than throwing shrapnel around
Oddly enough, this may be due in part to a manufacturing defect, as we've had one of the fittings come out as well, and AM has a note about it on their site. http://www.andymark.com/product-p/am-2649.htm
Originally Posted by JamesCH95 View Post
The compressor definitely outputs air warmer than 100F, evidenced by the compressor routinely getting "too hot to touch." I don't know if plastic tanks have ever gotten to that temperature, but the possibility is definitely there.
Next time I have the chance, I'll take some temperature readings of the tanks themselves after a few compressor cycles and see if there's any sort of noticeable increase in temperature. I wouldn't be surprised if the right setup (one where the tanks are essentially next to the compressor) was able to pump a bit of heat into the tanks...
Originally Posted by Racer26 View Post
1310s tank would have definitely seen temperatures (at least briefly) outside of that range, if only when transiting between their school and haul vehicle, and then into the venue. If the haul vehicle sat outside not running anywhere for a while, the tank could have conceivably seen temps in the neighborhood of -20C.
That's what I was thinking as well, but didn't know enough details about the situation to really say. I'm also not sure of how well the plastic tanks would handle heat cycling, specifically being exposed to temperatures outside of the operating range, then being brought back into the operating range before use.
-Dustin Benedict
  #62   Spotlight this post!
Unread 10-03-2014, 16:22
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Also consider that PP's CTE is an order of magnitude more than steel or aluminum, if a plastic tank and mounting bracket were warmed up together the PP would strain against any metal mounting components, perhaps significantly.
  #63   Spotlight this post!
Unread 10-03-2014, 17:38
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Originally Posted by Jim Wilks View Post
Is Clippard the only maker of plastic tanks? Are the ones from PneuAire also from Clippard, or does PneuAire make their own?. Anyone else?
Are all of the failures so far on Clippard tanks?
Before we call for a ban on all the plastic tanks, I think we really need to answer these questions. As far as I know PneuAire made the plastic tanks before Clippard started doing it. It was my understanding that Clippard released the 2013 plastic air tanks in response to teams using the PneuAire ones in the 2012 season.
We have used the PneuAire tanks (bought from PneuAire) without any failures for the past 3 years (only 2 in competition).
Safety is very important but we also shouldn't overreact.
  #64   Spotlight this post!
Unread 10-03-2014, 18:17
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Here I feel the opposite.
Considering the failure mode (sharp plastic shards flying a high velocity) I would err on the side of caution. Until we can prove that the plastic volumes are safe in a FIRST environment (High impact, low technical knowledge, large swings in temperature) I would want to ban the plastic volumes for foreseeable future starting next year.
P.S. Has a metal volume ever failed in a dangerous way in FIRST (they have a much longer history)
___________________
- Tennyson, Ulysses
  #65   Spotlight this post!
Unread 10-03-2014, 18:32
Engineering Coach
I'm not a plastics or pneumatics expert but I do know we don't ban all car seats when a single model is found to have manufacturing defects. Again I may be wrong and maybe the pneuaire tanks have a similar failure mode but lumping them together because they look the same seems like we are jumping to conclusions. I think we need more information.
  #66   Spotlight this post!
Unread 10-03-2014, 18:45
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Allen, I understand where you are coming from but as someone who has had a 1 liter PVC pneumatic volume explode within 1 foot of me (thank goodness it blew out away from me) I will respectfully disagree here.
The dangers to anyone near one of these if it explodes, especially to bystanders, some of which may be children, is too high for my liking. Thus I say 'ensure it is safe and then we can use it'.
___________________
- Tennyson, Ulysses
  #67   Spotlight this post!
Unread 10-03-2014, 19:34
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I would agree... however the case I saw up at LSR (and prompted me starting this thread) was not due to a manufacturing defect - it was due to improper use and handling by the team.
From what I've seen of plastics in general, I'm not aware of any that could be use in this application that wouldn't have a similar failure mode. Then again, I'm a software engineer and not a chemist or material scientist. Still, it worries me.
2016: Lake Superior WFFA
  #68   Spotlight this post!
Unread 10-03-2014, 19:47
Engineering Coach
I understand that point, I also understand that we need to better train teams to the dangers of pneumatics and for them to properly care for their equipment. The team in this case was operating illegally since the screw had to damage the air tank and thus modify it. There is a reason for this blue box in the manual.
Do not, for example, paint, file, machine, or abrasively remove any part of a pneumatic COMPONENT – this would cause the part to become a prohibited item. Consider pneumatic COMPONENTS sacred.
My point is that the PneuAir tanks have been in use on FRC robots longer than the Clippard tanks and I have never (doesn't mean it hasn't happened) heard of one of them failing do to misuse or defect.
  #69   Spotlight this post!
Unread 10-03-2014, 20:42
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I agree. User error is significantly more dangerous than any potential manufacturing defects. I don't think there is any substantial hazard from plastic tanks that are used appropriately. This includes not over tightening the fittings, not deforming the body and minimizing stress on the entire tank.
  #70   Spotlight this post!
Unread 10-03-2014, 21:00
Chris is me's Avatar
AKA: Pinecone
A pressurized, homemade PVC tank is incredibly different from an industry designed and rated part made of polypropylene. I get that these are scary, and I even wouldn't oppose phasing out / banning the white tanks with the screw fittings, but a blanket ban on anything that reminds you of something dangerous you were once near is a bit extreme.
As an aside, I'm interested to see what wrapping these tanks in gaffers tape would do for their failure mode. Obviously the pieces would rip through it, but the added resistance right as they start to gain velocity may be of more help than you'd think.
  #71   Spotlight this post!
Unread 10-03-2014, 21:06
Engineering Coach
Are you talking about all white plastic tanks with screw fittings or just the Clippard ones from 2013 that had a known failure and an optional recall? I really think we need to know more before we start making recommendations. This seems to be a pretty confusing issue, we don't know a lot about the differences between the different tanks (clippard, PneuAire, Andymark, etc.).
  #72   Spotlight this post!
Unread 10-03-2014, 21:09
Pat Hart Pat Hart is offline
FRC #0234 (Cyber Blue)
Pat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud of
Another means to address the safety concern of a light weight plastic tank would be a design that included either an integrated pressure release valve or a fail safe. Something that would release pressure in a known manner before catastrophic failure. This would allow lightweight tanks to continue to be used and eliminate the risk of a "user error" causing significant harm.
  #73   Spotlight this post!
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
For those teams still using the white Clippard volume storage tanks from last year, you should read the FRC Blog linked here dated January 30, 2013.
There are very specific instructions included on the safe installation of the fittings on these tanks. I'm not sure if Clippard will still replace them, however I personally know the Clippard family and company and I know they want to protect the safety and health of every FIRST participant, spectator and volunteer.
We currently use two of the new black vst from Clippard and are very pleased with them.
edit - Allen beat me to the post above...
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
  #74   Spotlight this post!
Unread 10-03-2014, 21:26
Bald & Bearded Bald & Bearded is offline
Jack of All Trades/Master on none
FRC #1885 (ILITE Robotics)
Bald & Bearded is on a distinguished road
First this is a great discussion with a lot of points on all sides of the issue.
I do have to agree with JesseK that if a simple and reliable solution is not identified FIRST will have no option but to go back to the metal tanks.
I would be great if we could get consumer reports, mythbusters or someone of that quality to test various sleeves/coverings.
I am not a physics person but from an intuitive point of view a sleeve/shroud of some kind should reduce the danger.
User error is the real issue.
  #75   Spotlight this post!
Unread 10-03-2014, 21:32
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
A relief valve won't solve the issue causing failures. Failures aren't caused by over pressurization in most cases (assuming in competition and with passed inspections). The problem is a degradation in pressure capacity due to mishandling the tanks (over tightening, improper mounting, etc.). What do you do when a tank fails at 100 PSI? 80? 60? If you put a crack in the right spot or damage a wall on a tank, any of these pressures could cause a failure in the right circumstance. The white Clippard tanks are great tanks, they just have very specific instructions for their use that are tough to follow perfectly. But they have a really phenomenal warning alarm when used improperly in the form of an explosive blast that will wake the neighbors and potentially kill you.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
