Go to Post The Scouting Award exists. It's called "Championship Winner". - Chris is me [more]
Unread 10-03-2014, 08:47
underdog1924 underdog1924 is offline
FRC #4909
underdog1924 is on a distinguished road
AndyMark 3CIM Single Speed Gear Box
Does anyone have a picture of an AndyMark 3CIM Single Speed Gear Box (http://www.andymark.com/product-p/am-14u-tc.htm) that is installed in their AM14U drive base? I'd like to get an idea of the space it takes up and any clearance issues.
Unread 10-03-2014, 09:31
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Re: AndyMark 3CIM Single Speed Gear Box
I have an image, but it's missing a miniCIM at the top.
http://i.imgur.com/kj65I7O.jpg
Unread 10-03-2014, 10:10
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
You can see ours in a few places:
https://twitter.com/rwallace931/stat...569409/photo/1
http://www.chiefdelphi.com/media/photos/39384
http://www.chiefdelphi.com/media/photos/39382
Richard Wallace
since 2003
Unread 10-03-2014, 18:34
FRC #4909
Thanks for the pics. Definitely not enough room in our drive base for those to fit. Oh well...
Unread 10-03-2014, 22:49
Oblarg Oblarg is online now
AKA: Eli Barnett
Out of curiosity, is it possible to change the gear ratio in the AndyMark 3CIM gearboxes? 8.46:1 is a bit slow for three CIMs on a 4'' wheel.
"The breakfast of champions!"
Unread 10-03-2014, 22:52
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Originally Posted by Oblarg View Post
Out of curiosity, is it possible to change the gear ratio in the AndyMark 3CIM gearboxes? 8.46:1 is a bit low for three CIMs on a 4'' wheel.
Look here for more ratios:
http://www.andymark.com/ToughBox-p/am-2760.htm
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 10-03-2014, 22:56
sailer99 sailer99 is offline
AKA: Sam
FRC #4476 (W.A.F.F.L.E.S.)
sailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud of
Yes, you can definitely change the gear ratios. The internals of the 3 CIM gearbox are the same as the regular toughbox mini so you can change gear ratios using the same upgrade packages. We use the 3 CIM upgrade gearboxes with the second stage reduction changed using 24 Tooth Gear to a 40 Tooth gear. This changes the overall reduction to 5.95:1 which we find works quite well.
AKA: Eli Barnett
Originally Posted by z_beeblebrox View Post
Ah. 5.95:1 is far more reasonable.
Might try these out next year instead of the WCP gearboxes, if they stick with the AM14U-style kitbot.
Unread 10-03-2014, 23:01
Billfred's Avatar
Billfred Billfred is offline
Knock on wood, they've been dead-on reliable through Palmetto and a lot of driver testing. We'd do it again!
Unread 10-03-2014, 23:05
Michael Yeh Michael Yeh is offline
Lead Chief Delphi Lurker & CAD/Mech
FRC #4099
Michael Yeh is an unknown quantity at this point
We purchased VexPro 44t and 20t gears and just the plates for the AndyMark gearboxes, intending to achieve a 7.86:1 ratio if we needed it. We also had the gears from the kit drivetrain, which seem to be identical.
The VexPro gears are thicker than AndyMark's due to the nub on both sides, though since we made our own spacers (churro tube) it wouldn't be difficult to grind down the nub or make longer spacers.
Another question about the 3CIM4U: is the output shaft supposed to be longer than the kitbot's? We recycled the one from the kitbot but since there's now 1/8" of gearbox in between it doesn't fully extend into the outer bearing.
Unread 10-03-2014, 23:07
AKA: Eli Barnett
Yeah, I don't see any reason to pay 2x the price for fancy looks; I'd have gotten these this year if we hadn't ordered our gearboxes on kickoff.
I've never had any problems with AM gearboxes with aluminum cases, and I've used loads of them over the years. I find their plastic ones are unsatisfactory, though.
Unread 11-03-2014, 19:26
nixiebunny nixiebunny is offline
AKA: David Forbes
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
We used the long shaft that came with the upgrade kit. It doesn't protrude fully into the bearing, but it is in deep enough to work. No troubles through the Hub City regional.
Beware that the inner spacing is also different due to the gearbox plate - we had to add a VexPro 1/2 hex plastic spacer between inner plate and wheel to keep the wheel hub bolts from scraping the inner side plate. We also had to file the AM14U bearing holes as the spacing between them was different from the 3CIM gearbox.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 11-03-2014, 20:49
AKA: Eli Barnett
We did this for our WCP gearbox, too, and it worked like a charm.
Unread 11-03-2014, 21:47
FRC #4099
Not having any of the Vex spacers on hand, we found that a 1/2" sch 40 PVC pipe fits loosely onto hex shaft. (0.622" nominal ID on .578" diagonal of the hex).
We didn't notice any issues with bearing spacing on the AM14U and 3CIM4U, but we'll double check when we get to Greater DC.
Also, clarification of "doesn't fully extend into the outer bearing" - the shaft from the plastic default box does ride on the outer bearing, just not all the way through so I assume the shafts are the same.
Unread 17-03-2014, 13:01
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
You should sell those yellow corner braces for the AM14U! We had to whip up something similar a day before bag-day on account of bent churros.
