Go to Post I've ridden the real Segway many times and I think it is a truly remarkable machine and worth every cent (if you have enough cents to spend on it). - sanddrag [more]
Unread 11-03-2014, 02:01
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Surgical tubing stretched too far
We have a catapult powered with surgical tubing on our bot. The tubing is stretched from about 5 inches untensioned to about 20 inches as the winch pulls down the catapult arm. That's a 300% increase in length.
During the Hub City regional, we suffered from frequent decreases in shooting power and had to re-tension the tubing several times over the three days, and we ended up replacing some of it. I suspect that the tubing is being stretched past its elastic limit. It displays "stretch marks".
We can modify the bot's superstructure to allow for a much longer untensioned length on the tubing, reducing the extension from 300% to about 100%. Does this sound like it will solve the tubing over-stretching problem?
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
