Go to Post Don't waste the opportunity because you were too focused on "winning" the championship. - Don Wright [more]
Unread 11-03-2014, 02:01
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Surgical tubing stretched too far
We have a catapult powered with surgical tubing on our bot. The tubing is stretched from about 5 inches untensioned to about 20 inches as the winch pulls down the catapult arm. That's a 300% increase in length.
During the Hub City regional, we suffered from frequent decreases in shooting power and had to re-tension the tubing several times over the three days, and we ended up replacing some of it. I suspect that the tubing is being stretched past its elastic limit. It displays "stretch marks".
We can modify the bot's superstructure to allow for a much longer untensioned length on the tubing, reducing the extension from 300% to about 100%. Does this sound like it will solve the tubing over-stretching problem?
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 11-03-2014, 02:14
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Surgical tubing stretched too far
You'd probably need a stronger grade tubing since you'll get less energy stored with less extension (E=1/2kx^2). Unless you're modifying your superstructure considerably.
Unread 11-03-2014, 07:12
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Had same issues a few years back until we went to spear gun tubing.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 11-03-2014, 07:17
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Yes, you will either need to switch out to a "stiffer" type of surgical tubing or add more strands of it; or both.
Note that while the equation for potential energy of a spring is E=.5*k*x^2, note that the k value for surgical tubing isn't constant as you stretch the surgical tubing. I would do some quick tests to determine the force required to deform to a certain length.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 11-03-2014, 07:27
tim-tim's Avatar
AKA: Tim Miedzinski
Spear gun tubing, that sounds interesting. Care to share any details? Like differences, mounting, pricing, sourcing, etc.
The RoboBees
Unread 11-03-2014, 07:28
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Go with spear gun tubing...the stuff is great.
http://www.amazon.com/Speargun-Sling...peargun+tubing
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 11-03-2014, 10:03
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
What Keegan said.
Unread 11-03-2014, 10:19
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
This equivalent to McMaster P/N 5234K65. You can search surgical tubing on McMaster and get a variaty of different wall thicknesses and outer diameter.
We have tried a couple of different ones and are also happy with the 1/2 OD and 3/16 Wall.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 11-03-2014, 10:25
Pi3th0n Pi3th0n is offline
AKA: Chase Mansell
FRC #0900 (Zebracorns)
Pi3th0n is on a distinguished road
On team 900 we've used surgical tubing power our catapult and we can shoot ~45 feet. We made sure to build it so that there's only 100% to 150% extension and we've not had to re-tension the surgical tubing.
So yes, it sounds like that probably will solve the over-stretching problem, but you'll probably have to tweak the # of wraps or something until it goes the distance you want.
Unread 11-03-2014, 12:56
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Can anyone confirm that the McMaster part is equivalent to the amazon link for the spear gun tubing (other than the dimensions) in terms of quality or rubber type?
We ran the McMaster tubing at our first competition and it definitely showed some wear and caused some issues in eliminations, I am wondering if the spear gun tubing will be better.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRST® or my affiliated team.[/center]
FRC® Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 11-03-2014, 13:43
Rstrzelecki Rstrzelecki is offline
FRC #0135 (The Black Knights)
Rstrzelecki is an unknown quantity at this point
We have been using 3/8 bungee to power our catapult. We found that it holds it's elasticity very well and we have yet to replace it.
Unread 12-03-2014, 00:24
AKA: Dave
I can't verify that they are the same as we haven't gotten the amazon stuff but they are both latex rubber. So can't be much different. What size did you try from McMaster?
There are many variables to what causes wear, such as attachment points and stretch %.
Unread 12-03-2014, 13:33
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I bought both the 'Spear it' brand spear tubing, and McMaster Latex Tubing and they appear to be identical, at least for our purposes.
Specifically, we've used both 12mm (1/2") Spear-it tubing, which seems to be identical to 1/2" OD, 3/16" wall latex tubing from McMaster.
-Dustin Benedict
Unread 12-03-2014, 14:54
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Another option, we went with the fitness bands. Find the force and corresponding diameters that work for your application and have fun. Our experience was a band reached its "advertised" force at approximately twice its original length. The brand carried by the chain sporting goods stores around here sells them in increments up to 100 lbs.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 12-03-2014, 21:21
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We are very happy with the 'KOP' linear force springs from Vulcan
Hundreds of shots, no change.
