Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 03-10-2014, 01:02 PM
themagic8ball themagic8ball is offline
AKA: Mike Weinand
FRC #0537 (Charger Robotics)
themagic8ball is on a distinguished road
BinaryImage Pixel Access
Does anyone know an easy way to get direct pixel access in a BinaryImage? Basically I just want a count of the 1 pixels vs the 0 pixels.
Unread 03-10-2014, 01:18 PM
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: BinaryImage Pixel Access
GetNumberParticles looks like it will do what you want (return the number of 1s, total bits can be calculated based on image size). GetImaqImage will return an Image* that can be passed to imaqGetPixel.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 03-10-2014, 01:59 PM
AKA: Mike Weinand
GetNumberParticles only works after a particle filter is applied, we tried that. imaqGetPixel may do the trick. Thanks!
Unread 03-10-2014, 03:26 PM
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
(Info largely based off of Google searches)
Calling imaqGetPixel repeatedly will probably give you very bad performance. If you're using C++, try imaqGetImageInfo instead to get direct access to the pixel data. See here for an example of how to use it.
If you're using LabVIEW, there's a imaqImageToArray function, but this creates a copy of the image data, and so will be slower than the imaqGetImageInfo method.
You could also call imaqQuantify which returns summary statistics about the image, include the mean pixel value. You can multiply the mean by the pixel size of the image (width*height) to get the number of 1 pixels.
FRC 766, 2015-, Mentor
Unread 03-10-2014, 03:31 PM
AKA: Mike Weinand
Appreciate the note on performance.
Unread 03-11-2014, 09:55 AM
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
If you're using opencv, look into image moments.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
