Go to Post FIRST, grant me the serenity to accept the things I cannot drill, Courage to drill the things I can, And wisdom to know the difference. - Bill_B [more]
Unread 11-03-2014, 11:04
shanek21 shanek21 is offline
AKA: Shane Kelly
FRC #5052 (RoboLobos)
shanek21 is an unknown quantity at this point
Back Driving Problems
My team has been having problems with back driving on our winch system that is used to reload our launcher. We have thought of a few possible solutions to this problem, but have encountered some difficulties implementing them. We have attempted introducing a ratchet into our gearing system, but any shafts that we could use to stop back driving issues are completely round, making it difficult to attach a ratchet to. We have also considered a gate latch system using a piston as a hard stop to eliminate back drive, but we have very few pneumatic components and this sort of rig would take away our ability to execute variable shots. I was just wondering if any other teams had found creative solutions to stop back driving issues in super shifters or catapults in general or had any advice on this subject.
Thanks in advance,
Shane
Unread 11-03-2014, 11:14
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Re: Back Driving Problems
Yes, we did something a little different that may work for you. We mounted a 36 tooth sprocket onto the side of our winch using bolts. As the winch spins, the sprocket spins with it. We then have a pneumatically powered lever with a steel pin mounted to it. When the lever is engaged, the pin rests inside one of the grooves/teeth of the sprocket preventing the winch from back driving. It works very well. If you are considering this, then I can post a picture.
I don't know what your setup looks like, so it may be hard to fit a sprocket on your winch but it worth a try.
-Keegan Harrington
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 11-03-2014, 11:29
AKA: Shane Kelly
-Keegan Harrington
A picture would be greatly appreciated! If I am understanding you correctly, then I think we may be able to implement something similar on our winch using this concept. Thanks so much!
As a side note, I would still be interested in seeing other creative ways that teams have solved this same issue!
Unread 11-03-2014, 11:32
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
chris.boyle is on a distinguished road
To expand a little bit more on TheKeeg's explanation. The pin s controlled by the motor activation. When the motor is requested to move, the pin is released, when it stops, the pin is placed back in the sprocket. All automated in the software.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 11-03-2014, 11:33
TheKeeg's Avatar
I will post one to this thread as soon as I can. It may be a few hours though.
Keegan Harrington
Truck Town Thunder
Unread 11-03-2014, 11:51
AKA: Shane Kelly
So, when the motor is requested to move is the pin retracted via the piston, the motor moves, and then the pin is replaced in order to prevent back drive?
Awesome! I look forward to it.
Unread 11-03-2014, 11:56
TheKeeg's Avatar
Exactly.
Keegan Harrington
Truck Town Thunder
Unread 11-03-2014, 12:18
eli2410's Avatar
eli2410 eli2410 is offline
Alumni/UCF Student
FRC #2410 (Metal Mustangs)
eli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of light
In 2010, we used a Dewalt Drill Transmission to drive our kicker mechanism, and it almost impossible to back drive it. There is a white paper on how to attach it to most of our motors. You can also buy a Dewalt transmission from Dewalt directly for somewhere around $40 (can't find the link). They work really well.
The BIGGEST warning I have about them is to work carefully with it and follow the instructions from the white paper. They are extremely complicated and very hard to reassemble if they become disassembled (such as dropping it on the ground like we did at championships. Fortunately, there was some from Dewalt standing nearby who reassembled it for us in 15 seconds.) We just tried to service it, it took us two days to figure out.
Co-captain:
2013: Cowtown Throwdown-Winners
2014: Greater KC Regional-Judges Award & Oklahoma Regional-Judges Award and Dean's List Finalist (Lauren Pudvan)
Team Member:
2013: Razorback Regional-Team Spirit & Woody Flowers (Mr. Ritter) & Greater Kansas City Regional- Gracious Professionalism
2012: FIRST Championship in St. Louis, Oklahoma Regional- Team Spirit Award, & Greater Kansas City Regional
2011: Midwest Regional & Greater Kansas City Regional- Innovation in Control
Little Brother (Spectator):
2008: FIRST Championship in Atlanta & Greater Kansas City Regional
Unread 11-03-2014, 12:37
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
What are you using to retract your winch? If you use the right gearbox/motor combination, it won't backdrive at all. For example, our winch was originally retracted by a BAG motor in a 100:1 planetary gearbox, and when the motor was unpowered, it backdrove extremely slowly (we used a talon SR to control the motor so it automatically applied brakes when it wasn't powered). At this point all it took was to program the motor to servo to a specific position and it would hold it there without any other mechanical lock. The BAG motor was capable of holding this position for several minutes and barely even got warm. Recently we switched to a 50:1 planetary, which backdrives faster and requires more power to hold, but the BAG still holds the position fine for us. We use an encoder on the winch shaft to keep track of our loaded position and a VEX ballshifter to shift from engaged to neutral, so we just hold the winch in place then disengage the shifter to fire. This also allows us to vary our shot power, because we can just change the winch position target and the motor will hold it there.
There are other options, too- some gearboxes fight backdriving by design, such as a worm-drive similar to the window motor gearboxes. However, all of these ideas hinge on whatever method you use to fire.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 11-03-2014, 13:28
AKA: Shane Kelly
Having enough torque on the system to prevent back driving would be the ideal situation for our winch, but we are very limited on funds and basically only have what has been donated to us, which in this instance is a supershifter. Do you have any suggestions for a relatively cheap alternative to the ratio that we get from the super shifter? We are able to allocate two CIMs to our winch, which would theoretically give us enough power, we just don't seem to have enough torque through the super shifter's gear ratio.
Unread 11-03-2014, 13:57
I'm not too familiar with super shifters, but do you know what ratio you are running? How fast does it winch back all the way? What type of speed controllers are you using for the CIMs? Unfortunately, CIMs draw so much power that it's probably not practical to try to hold position with them, or they might get hot and drain your battery. If this is the case, you will have to investigate one of the mechanical locks discussed in this thread. With the lower gear ratios that super shifters use, they are significantly easier to backdrive then a 50:1 or 100:1 gearbox, so holding your winch with the motor is probably not your best bet. However, don't take my word for it- do some testing if you have the chance.
Unread 11-03-2014, 14:12
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Take a look at a disc brake used for mountain bikes and a cylinder to pull the cable. You could use a left of right hand 1/4-20 threaded screw on the end of a shaft
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 11-03-2014, 16:14
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
We made a custom gearbox that uses a worm gear, which inherently does not back drive.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 11-03-2014, 16:41
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
If you're shifting into neutral with a supershifter, that means at least two gears aren't being used. You can pull those gears out, expose some hex, and stick in a ratcheting wrench.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-03-2014, 16:44
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
My team used a one-way bearing with a manual disengage via piston. It's the most consistent part of our robot. Probably not the most elegant, but it works and was relatively easy to do.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
