Go to Post Sometimes people are just offended too easily. Sometimes offensively so. - GeeTwo [more]
Unread 19-02-2003, 05:09
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
feedback? See now you let me start talking...that can be long. It might be a bit too late but here it is.
The idea is cool, I was wondering though...is it topheavy? Because if it is at all as soon as that starts swinging that weight on the top would most likely count for more and more... Is the wood suppose to be used to make it heavy at the bottom or was it for a shield? There are lighter shields you could use (thin plastic?) if topheavyness isn't a problem allowing you that weight to make the braces holding the swinging arm more steady if that is needed or just to reposition that weight with some sort of spare weight so you can position it better or lower giving you better balance. I know it is wood and not a huge difference but it isn't hard and could help...
Also that is going really easily knock over other people's stacks even while guarded which could be huge as a side thing. It's cool, I haven't seen many of those.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Great Job Team Cyber Blue - 234 234EP Thanks and/or Congrats 0 13-04-2003 14:39
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Cyber Blue archiver 2000 0 23-06-2002 22:48
