Go to Post Silly FIRST mentor -- actually spending brain power caring about a sporting event occuring during build season! - Aidan F. Browne [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 17-02-2014, 11:57
Math Quiz: Parabola Path
The center of a circle of radius=1 traverses the parabolic trajectory.. y = -0.0433*x2.. from x=-5 to x=+5 in the XY plane, and as it does so it "sweeps out" a path with upper and lower boundaries.
Find the equations for the upper and lower boundary curves.
Unread 17-02-2014, 16:25
Re: Math Quiz: Parabola Path
Hint: the answer is not
y = -0.0433*x2 + 1
and
y = -0.0433*x2 - 1
Name:	not + - 1.png
Unread 17-02-2014, 18:08
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
I get:
Top curve: y = -0351x^2 + 1
Bottom curve: y = -.0433x^2 - 1
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 17-02-2014, 18:29
Originally Posted by Qbot2640 View Post
I get:
Not. See my previous post.
I get:
I assume there's supposed to be a decimal point before the "0".
Nice try, but no cigar.
Unread 17-02-2014, 18:40
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
My mistake...I had all three equations together, and grabbed your original as the "bottom". The top I got (as you corrected my missing decimal) is 0.0351x^2 + 1
The bottom I got was 0.0474x^2 -1
I calculated two normal lines and found points that were 1 unit away from points on your given original. Then calculated the quadratics from the two sets of three points (although the y intercepts being known, one really only needs two points).
Unread 17-02-2014, 19:16
The top equation y = -0.0351x^2 + 1 is still not right (even with the required "-" sign added back in )
The bottom equation y = -0.0474x^2 - 1 (with the "-" sign added) is a very good approximation in the given range, but as you can see in the attached graph, it diverges outside that range.
You've got the right general idea.
Then calculated the quadratics...
Hint#2: the top and bottom boundary curves are not true quadratics.
Unread 17-02-2014, 19:24
Graph of upper and lower boundary curves
Unread 02-03-2014, 20:40
Any math/physics teachers want to give this a try?
Unread 03-03-2014, 00:02
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Can I give the answers in parametric form?
Spoiler for parametric plot equations:
xlower(t) = t - 0.0866 t / √(1 + (0.0866 t)2)
ylower(t) = -0.0433 t2 - 1 / √(1 + (0.0866 t)2)
xupper(t) = t + 0.0866 t / √(1 + (0.0866 t)2)
yupper(t) = -0.0433 t2 + 1 / √(1 + (0.0866 t)2)
FRC 766, 2015-, Mentor
Unread 03-03-2014, 09:51
You got it
Reps to you !
Unread 06-03-2014, 17:57
Is it possible to represent Ryan's parametric equations in explicit form y=f(x) ?
Or even implicit f(x,y)=0 ?
Unread 11-03-2014, 16:45
Does anyone have access to Mathematica?
Unread 11-03-2014, 18:32
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
http://www.wolfram.com/mathematica/trial/
Unread 11-03-2014, 18:44
Originally Posted by cgmv123 View Post
Thank you, I am aware of that. For a variety of reasons, I don't install or use trial software.
Are there any Mathematica gurus out there in CD land?
Unread 11-03-2014, 20:07
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
As a function of x, it will describe the upper boundary on one side and the lower on the other. It does exist, but it is very ugly. I will try to remember to post it later.
--Jacob
Illinois FTC FTA
