Go to Post Their robot moves so fast that it changes colour due to the Dopler Effect. By rapidly alternating between driving away from the viewer (Redshift) and driving toward the viewer (Blueshift), they can make the viewer see it in their traditional purple colour. - philso [more]
Unread 11-03-2014, 20:01
dannybhoy's Avatar
dannybhoy dannybhoy is offline
dannybhoy is an unknown quantity at this point
Conveyor Belt treads idler & Sprocket help
Hello everyone!
This is my first post here, not entirely sure I am post this in the correct location.
I am want to get some suggestions on how to drive a conveyor belt I purchased for a large scale robot I intend to build. The conveyor belt I purchased is from McMaster Carr (Link here). The belt has a smooth, cloth backing which is where I'm at a loss. I've seen most of them that have ridges or something to grab onto so it can be driven but in this case I can't. Is there a way to modify this belt? Or, do I need to cut my losses and purchase another belt from McMaster?
Unread 11-03-2014, 20:53
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Re: Conveyor Belt treads idler & Sprocket help
Never made a conveyor belt before.
But I would probably just tension the belt nice and tight, and friction drive it. That is, get some sort of rubber rollers for it to ride on, and just drive one of them.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 11-03-2014, 21:01
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
We did something similar for our frisbee shooter last year. Totally depends on the appilcation
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 11-03-2014, 21:08
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by dannybhoy View Post
Hello everyone!
Drive the conveyor with a roller (maybe attach a sprocket on the end to connect to the motor). I'd put a covering of non-skid (a kind of tape that feels like sandpaper) on the roller.
Put a roller on the other end and tension appropriately (you may need to add guides to the ends of each roller if it tracks off of the rollers).
In the middle add bogeys (rollers with some spring force to keep the conveyor from getting pushed in) or a press plate (to back the conveyor, again to keep the conveyor from getting pushed in).
BTW: Welcome to CD
___________________
- Tennyson, Ulysses
Unread 20-03-2014, 00:49
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Buy some rollers that are made for the job.
Steel rollers are usually used for this application, although nylon rollers will work also for lower tensions. A slightly convex roller is usually used on one end, so that the belt stays centered automatically.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 20-03-2014, 03:44
RoboChair's Avatar
RoboChair RoboChair is online now
AKA: Devin Castellucci
As counter intuitive as it may seem, do not add sides to the belt, it WILL ABSOLUTELY somehow find a way to ride up onto one side or the other(such a happy accident with my first robot ever in 06)! What you want is to have your drive rollers be slightly ovoid in shape a "crowned pulley", the more egg shaped the less it will drift due to side loads. This link https://woodgears.ca/bandsaw/crowned_pulleys.html shows how crowned pulleys do what they do.
Watching a crowned pulley high center and automatically adjust a belt as side loads are applied for the first time is like spooky voodoo magic happening right before you. You just want to see it roll off the side but nope it just chills out in the middle.
