Go to Post FIRST is more than FRC. - gblake [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 11-03-2014, 22:15
bbradf44's Avatar
bbradf44 bbradf44 is offline
AKA: Brad
FRC #3344 (Robocopz)
Team Role: Driver
bbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nice
Question HTMLish based scouting
So im not even sure if this is possible, but ill give it a shot and see what people think. This year we are running scouting in the stands through either MS Excel or Access so that it can be run through Tableau. Our current setup requires all 6 scouts to have forms to fill out while the 7th inputs them into the database, then an 8th person runs a USB flash drive back and forth to the pits whenever we want to update where we have the Tableau program running. I got the idea while in my web design class today, would it be possible to have an HTML form running on cell phones or other 3g/4g enabled device that when the submit button is pressed, it sends the data to the database that will be either on our team website or in the cloud, which i can then open on my laptop in our pit(usb tethered to my phone)? The html file itself wont be online(but maybe i could put that on our website too) but rather stored on each of the phones. Ideas/criticisms welcome
Unread 11-03-2014, 22:32
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
A couple of years ago we did something very similar to this approach. I set up a "Google Form" that any of the scout could run from any smartphone. They would enter the data for each robot/match. This data was stored in a google spreadsheet. Every 5 matches or so, I would download the data into excel (via a tethered hotspot) and then read it with a similar tool to Tableau (QlikView). Now we use an in-house developed Android app that loads data into a SQL database, but is still read via the dashboard. Hope this helps.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 11-03-2014, 22:46
bbradf44's Avatar
AKA: Brad
Team Role: Driver
That actually helps a lot. And here I am trying to over complicate things again with HTML and such. So did you have to re download the excel data every time or would you just be able to refresh if you have the Google drive installed?
2011: FRC 1922 Team Member
2012 (Build weeks 1-3): FRC 1922 Team Member
2012 (Weeks 4-Competition): FRC 3344 Mechanic and Pit Crew
2013: FRC 3344 Mechanical Lead and Head Driver
2014: FRC 3344 Team Captain and Head Driver
Record as driver: 7-11-0 and Proud of it
Unread 11-03-2014, 23:15
SteveGPage's Avatar
AKA: Steve
I'm glad it helps! I took the programming easy route and just reloaded the entire data set. It didn't take but 3 or 4 seconds, so I didn't worry about trying to just load the new records. At the time, I didn't have Google Drive installed, so I might do it differently now if that was what we are doing now.
Unread 11-03-2014, 23:17
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
Re: HTMLish based scouting
The simplest way to do this is to have an HTML based input page that sends the form data to an SQL database. To read the data, you can use PHP and do almost any type of analysis you would like. Very simple and straightforward.
If you don't want to deal with an internet connection, you can run a simple WAMP server (or equivalent) on a laptop and connect all the scouting laptops together using an ethernet switch. It will run exactly like a website server, except on a laptop. We ran a system like this at IRI, Fall Classic, Battle at the Border, and CVR.
There is a learning curve involved, but the FRC community is an amazing resource.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 13-03-2014, 01:53
terabyte128 terabyte128 is offline
AKA: Sam
FRC #4030 (NullPointerException)
Team Role: Webmaster
terabyte128 is an unknown quantity at this point
We are taking a similar approach this year, but opting to store all the information in a MySQL database in the cloud (as well as the entire website). Of course, the downfall of this is that without a cellular connection we're sort of screwed.
Eventually I'd like to integrate Tableau, but we're just working with a simpler graphing plugin right now. I might run it locally off my laptop for the next competition if we can't get a good internet connection. It does make scouting much easier to just eliminate paper entirely. We also have an interactive system for data entry and automatically generated statistics based on teams.
If you're curious you can view the application here (source code)
Unread 13-03-2014, 10:46
aryker's Avatar
aryker aryker is offline
FRC #0868 (TechHOUNDS)
aryker will become famous soon enougharyker will become famous soon enough
We're doing something similar for our scouting system this year. We have a Raspberry Pi running a web server that hosts the HTML forms, and when you submit, the data gets stored in a MySQL database on the Pi. We've got web pages for data visualization and match prediction, as well as an Android app that we wrote for our coach's tablet that can grab the latest data from the database and then be used for strategy anywhere after being disconnected. Basically what this means is that any device with a web browser and an ethernet connection can be used to scout. We ordered some Chromebooks for our scouts to use in the stands. We're actually working on a final version to release to teams in the next week, so I'll be posting about that soon.
Unread 13-03-2014, 10:58
Joining the 900 Meme Team
FRC #0079
I tossed together a quick AngularJS app for talking to Parse.com to store my data (debated hitting Google Docs but Parse was just easy). Maybe I'll clean it up and open source it this weekend.
Unread 13-03-2014, 11:11
bbradf44's Avatar
AKA: Brad
Team Role: Driver
Thanks for all the reply's. For now it looks like im going to test out the google form method and see if i get the desired effects in tableau that i can get with access. We will be trying the MySQL method but probably wont have it completed before Peachtree. Im almost positive we will have a good cellular connection in the middle of Atlanta but you never know, so we will keep the access method i had come up with before as a backup
Unread 13-03-2014, 11:12
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
One issue here is I've never been to an event with a solid data connection. Your system is entirely dependent on that, and will cause headaches and frustration at game time.
Simpler, less dependent solutions I've seen were applications that store the data locally and then push the data to a local server by the push of a button. You're on a good path with using HTML and <form> tags, though. This would also eliminate the 8th person; the 7th person's job is handled by computers, making more people available for other important jobs at competition. Additionally, you can setup Tableau on the local server, and print out data for your upcoming matches to run down to the pits, eliminating extra time needed to process the data in the pits, while still making the data available for developing strategy.
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 14-03-2014, 16:06
xSAWxBLADEx's Avatar
xSAWxBLADEx xSAWxBLADEx is offline
DaBears til 13 turned Free Agent 14
AKA: Michael Hawley
no team (Free Agent)
Team Role: Scout
xSAWxBLADEx will become famous soon enoughxSAWxBLADEx will become famous soon enough
Send a message via MSN to xSAWxBLADEx
My old team tried everything, Sql servers, excel spreadsheets, etc. and at the end of the year we always resorted back to paper and pens. Yes, we had the OPR data and raw match data ran through a excel database much like Ed's, but real match scouting was paper and pens. Sorry tree huggers, I have to admit I love killing the trees if it meant getting clean scouting forms.
2006-Palmetto Regional Champions with 11 and 1251 (MORT, TIGERS, BEARS, O MY!)
2007-Pittsburgh Regional Champions with 123 and 337 / Detroit Regional Champions with 123 and 903
2009-Traverse City District Competition Champions with 85 and 2645 / Traverse City District Competition Chairman's Award / Michigan State Championship Finalists with 1918 and 904 / Championship Finalist with 217 and 68
2013-Grand Blanc District Competition Champions with 33 and 1718
Unread 14-03-2014, 17:16
Wait... what does this have to do with the thread?
Unread 14-03-2014, 22:26
AKA: Michael Hawley
Team Role: Scout
I am just saying we tried using computer to aid with scouting, and it didn't work for us. I am just letting other teams know that if html scouting doesn't work, paper is a wonderful alternative.
Unread 15-03-2014, 00:46
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
Our team developed a html/js scouting application that wrote .csv files for each match and could also collect every match.csv file to compile a "master" file which has data about each robot based on the match data. Worked pretty well at our last district.
https://github.com/FRC-Team-955/AerialAssistScouting
Unread 15-03-2014, 10:39
wesleyac's Avatar
wesleyac wesleyac is offline
AKA: Wesley Aptekar-Cassels
FRC #1678
wesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to behold
You can also eliminate the person who runs down to the pits by storing it on a server. Although that depends on data as well. As for data issues,storing to disk can help. That way, if it's a temporary issue, you can upload it later, or if it's a major issue, print it or run a laptop/tablet to the pits.
Our team does something similar to this. We haven't had issues with cell data yet.
Originally Posted by The programming team
Define "works."
[IMG] code is Off
