Go to Post Winning medals and awards, being on TV or in a magazine while cool doesn’t even begin to compare to the relationships I’ve developed working with a bunch of great students. - ebarker [more]
Unread 12-03-2014, 12:03
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Bumper Wood
Originally Posted by Daniel_LaFleur View Post
Is that anywhere in the rules, or just interpretation?
R21.
Based on LRI training, the provisions in part A (allowing small clearance pockets and/or access holes) are there to facilitate meeting part F (rigid fastening system to form a tight, robust connection to the main structure/frame).
We're looking for something that matches the provided bumper cross section (figure 4-8) as closely as possible for its entire length, with exceptions made to allow for tight, robust mounting. The bumper rules don't take into account robot mechanisms - your mechanisms need to be designed to take into account bumpers.
A lot of teams (most teams, probably) leave bumpers until the very end. They spend 6 weeks working on a beautiful robot, then give a freshman a single night to come up with suitable bumpers. Some years, it doesn't matter as it's relatively easy to manipulate a game piece over, under, or around the bumpers. Other years, like this year, the bumpers really play a big role in game piece manipulation for a lot of teams. Having the bumpers in place changes the geometry and motion required for the ball to enter the robot. Personally, I'm a big fan of making some bumpers as soon as you have a frame and strapping them in place. It'll help you remember to include all of the constraints when designing your manipulators.
2016: Lake Superior WFFA
Unread 12-03-2014, 12:30
xxvg xxvg is offline
FRC #2443
xxvg is an unknown quantity at this point
Re: Bumper Wood
https://mail.google.com/mail/u/0/?ui...&sz=w1254-h520
So is this legal if there is this small clearance is on the top?
Unread 12-03-2014, 12:42
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Bumper Wood
From your link:
.....Forbidden That’s all we know.
But probably not. Remember Q&A initially said that since tape is not in the profile for bumpers, you could not use tape. Notches are definitely not there. You might get it through your inspectors. But if they say no & get pushed, it is eventually go to Al & you know his answer
Unread 12-03-2014, 12:46
wet_colored_arc wet_colored_arc is offline
FRC #1126 (SparX)
wet_colored_arc is an unknown quantity at this point
Re: Bumper Wood
I really hate to discourage you but I agree with most the other comments. Even not doing things like this we have occasionally had variations in some details of interpretation. Before my time involved with FIRST, the team got through an entire regional and then qualifications at another regional only to be asked to change something for finals when re-inspected.
I have always interpreted the spirit of the rule to provide for some minimum standard protection for your robot that is wholly independent of aiding function of the robot. In this case, not a true "aide" but certainly an accommodation.
Having said that, read the rules carefully. Maybe you can design around the 8" constraint or maybe consider the tolerances on cutting the wood.
Unread 12-03-2014, 18:06
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Bumper Wood
One other clarification that I don't think has come up in this discussion.
If you have more than 8" of bumper (say 12" ) from the corner, the 8" minimum rule still does not allow you to notch between the 8" and 12" locations.
A bumper may cover only the minimum 8", but if its longer, all of it still has to fit the bumper rules and match the bumper cross section specifications.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 12-03-2014, 18:25
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bumper Wood
The rules are pretty clear that you must use wood that is 5" x 3/4 thick. A notch that brings the wood to <5" violates the rule.
That being said, remember that the bumpers can be as low as 2" off the ground, so if the top of your bumper is > 7" from the ground perhaps you can lower it/them.
Regretfully, if your design will not function when a legal bumper is in place, you are somewhat out-of-luck, and it becomes a lesson-learned for next year: Read the rules carefully.
Unread 12-03-2014, 18:39
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Bumper Wood
Technically the rule is that the wood is 5" +/- 1/2" high so a bumper who's backing is 4 1/2" high would be legal under the current rules.
Unread 12-03-2014, 18:42
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bumper Wood
Yes indeed, it would.
