Go to Post You just have to care enough to give it a try. Your mentors will appreciate the effort. - Koko Ed [more]
Unread 12-03-2014, 01:46
xxvg xxvg is offline
FRC #2443
xxvg is an unknown quantity at this point
Bumper Wood
Is it legal to cut off a piece of the bumper wood since it is hitting our robot's intake when the intake comes down? or is it illegal? I need some clarification on this. Thank you.
Unread 12-03-2014, 01:52
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Bumper Wood
Specifics? Drawings? Anything?
It depends where you're cutting from.
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Bumper Wood
You need at least 8 inches of bumper from the corners of your robot, if the part hits the bumper after that point, you are okay to not have bumper for that area.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 12-03-2014, 01:58
FRC #2443
Re: Bumper Wood
It is just a v shape cut on the top on the wood, measure about like an inch width, so like a triangle. There's two of them so when our intake comes down to take in the ball it doesn't hit the bumper. The bumper wood interferes with our intake and how it is supposed to take in the ball.
Unread 12-03-2014, 02:02
SteveGPage's Avatar
SteveGPage SteveGPage is online now
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Based on your description, it is very likely that modification is illegal. Additional details, measurements, pictures, etc would be helpful to give better advice.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 12-03-2014, 08:56
Re: Bumper Wood
XX,
A legal bumper is one in which...
R21
BUMPERS must be constructed as follows (see Figure 4-8):
A. be backed by ¾ in. (nominal) thick by 5 in. (± ½ in) tall plywood or solid, robust wood.
Unread 12-03-2014, 10:39
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Bumper Wood
XX,
R21
Al the full rule reads:
Originally Posted by FRC Rules
R21BUMPERS must be constructed as follows (see Figure 4-8):
A. be backed by ¾ in. (nominal) thick by 5 in. (± ½ in) tall plywood or solid, robust wood. Small clearance pockets and/or access holes in the plywood backing are permitted, as long as they do not significantly affect the structural integrity of the BUMPER.
So the question is: If it is a small access hole (for the intake) and does not affect structural integrity, is it legal?
___________________
- Tennyson, Ulysses
Unread 12-03-2014, 11:10
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Bumper Wood
No. The access holes are for bolt heads so that the bumper will fit against the frame.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 12-03-2014, 11:25
Re: Bumper Wood
Steve's interpretation is the one used in inspection. A notch does not meet that criteria.
Unread 12-03-2014, 11:34
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Bumper Wood
Is that anywhere in the rules, or just interpretation?
___________________
- Tennyson, Ulysses
Unread 12-03-2014, 11:41
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Bumper Wood
Realize that you are saying that a 5" wide piece of wood reduced to 4" at one (or two) locations doesn't affect structural integrity. How does that work?
The access holes for fasteners do effect structural integrity of the wood, but overall enhance the robutsness of the bumper system by getting more backing contact with the frame.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 12-03-2014, 11:47
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Bumper Wood
See the 2014 FRC Game Manual, Section 5 The Tournament, part 5.5.2: At each event, the Lead Robot Inspector (LRI) has final authority on the legality of any ....
LRIs do not invent rules interpretations on the fly, they base them on training. That training comes from FIRST HQ, through the Chief Robot Inspector -- that would be Al.
Richard Wallace
since 2003
Unread 12-03-2014, 11:56
Re: Bumper Wood
Daniel,
That is the standard interpretation based on past practice. It has always been used to allow a tight fit to the robot frame. (although in some years it was not allowed)
Unread 12-03-2014, 11:57
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Bumper Wood
There was a team at Arkansas who asked the very same question. They wanted to make a notch in the bumper to accommodate their intake mechanism because their intake was designed without the bumpers. Andy, our LRI, said "Absolutely not." Their intake was unfortunately too wide to just "not have bumpers" where the intake and robot body met; they didn't have the 8" on each corner clearance.
You aren't REQUIRED to have bumpers that cover EVERY inch of the perimeter of your robot - depending on the design of your intake along with the rest of your frame perimeter, would it be possible to just NOT have bumpers at your intake point? Is there enough space for bumpers 8" on each side of the corners of your robot?
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 12-03-2014, 12:03
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Bumper Wood
R21.
Based on LRI training, the provisions in part A (allowing small clearance pockets and/or access holes) are there to facilitate meeting part F (rigid fastening system to form a tight, robust connection to the main structure/frame).
We're looking for something that matches the provided bumper cross section (figure 4-8) as closely as possible for its entire length, with exceptions made to allow for tight, robust mounting. The bumper rules don't take into account robot mechanisms - your mechanisms need to be designed to take into account bumpers.
A lot of teams (most teams, probably) leave bumpers until the very end. They spend 6 weeks working on a beautiful robot, then give a freshman a single night to come up with suitable bumpers. Some years, it doesn't matter as it's relatively easy to manipulate a game piece over, under, or around the bumpers. Other years, like this year, the bumpers really play a big role in game piece manipulation for a lot of teams. Having the bumpers in place changes the geometry and motion required for the ball to enter the robot. Personally, I'm a big fan of making some bumpers as soon as you have a frame and strapping them in place. It'll help you remember to include all of the constraints when designing your manipulators.
2016: Lake Superior WFFA
