Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Unread 12-03-2014, 12:30
xxvg xxvg is offline
FRC #2443
xxvg is an unknown quantity at this point
Re: Bumper Wood
https://mail.google.com/mail/u/0/?ui...&sz=w1254-h520
So is this legal if there is this small clearance is on the top?
Unread 12-03-2014, 12:42
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Bumper Wood
From your link:
.....Forbidden That’s all we know.
But probably not. Remember Q&A initially said that since tape is not in the profile for bumpers, you could not use tape. Notches are definitely not there. You might get it through your inspectors. But if they say no & get pushed, it is eventually go to Al & you know his answer
Unread 12-03-2014, 12:46
wet_colored_arc wet_colored_arc is offline
FRC #1126 (SparX)
wet_colored_arc is an unknown quantity at this point
Re: Bumper Wood
I really hate to discourage you but I agree with most the other comments. Even not doing things like this we have occasionally had variations in some details of interpretation. Before my time involved with FIRST, the team got through an entire regional and then qualifications at another regional only to be asked to change something for finals when re-inspected.
I have always interpreted the spirit of the rule to provide for some minimum standard protection for your robot that is wholly independent of aiding function of the robot. In this case, not a true "aide" but certainly an accommodation.
Having said that, read the rules carefully. Maybe you can design around the 8" constraint or maybe consider the tolerances on cutting the wood.
Unread 12-03-2014, 18:06
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Bumper Wood
One other clarification that I don't think has come up in this discussion.
If you have more than 8" of bumper (say 12" ) from the corner, the 8" minimum rule still does not allow you to notch between the 8" and 12" locations.
A bumper may cover only the minimum 8", but if its longer, all of it still has to fit the bumper rules and match the bumper cross section specifications.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 12-03-2014, 18:25
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bumper Wood
The rules are pretty clear that you must use wood that is 5" x 3/4 thick. A notch that brings the wood to <5" violates the rule.
That being said, remember that the bumpers can be as low as 2" off the ground, so if the top of your bumper is > 7" from the ground perhaps you can lower it/them.
Regretfully, if your design will not function when a legal bumper is in place, you are somewhat out-of-luck, and it becomes a lesson-learned for next year: Read the rules carefully.
Unread 12-03-2014, 18:39
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Bumper Wood
Technically the rule is that the wood is 5" +/- 1/2" high so a bumper who's backing is 4 1/2" high would be legal under the current rules.
Unread 12-03-2014, 18:42
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bumper Wood
Yes indeed, it would.
Unread 12-03-2014, 18:57
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
This is because all BUMPERS are exempt from size and weight restrictions. Free weight generally comes with conditions.
Unread 12-03-2014, 20:46
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: Bumper Wood
Howzit,
I believe if you are to use a combination of two previously mentioned resolutions to possibly make your intake work.
Measure the floor clearance of your existing bumper. If you are at 3" or more you have an easy fix of lowering the bumper.
Even if you are able to lower the bumper only a 1/2 inch you then can make the wood backing 4.5" and you will get your needed inch.
As mentioned by Jon "the bumpers really play a big role in game piece manipulation for a lot of teams. Having the bumpers in place changes the geometry and motion required for the ball to enter the robot. Personally, I'm a big fan of making some bumpers as soon as you have a frame and strapping them in place. It'll help you remember to include all of the constraints when designing your manipulators."
This is really important.. I am personally not a fan of corner only bumpers, I have seen many robots this year getting hung up on one another during heavy defense.
Good luck with your bumper revisions, and upcoming events.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 13-03-2014, 08:19
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Bumper Wood
This is not quite true. There is size minimums and weight maximums. There are also condition on what can and can't be used on a bumper.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 13-03-2014, 08:58
cgmv123's Avatar
AKA: Max Vrany
Re: Bumper Wood
I was referring to ROBOT sizing and ROBOT weight restrictions, but yes, I was being unclear. BUMPERS have their own set of size and weight restrictions as well.
Unread 13-03-2014, 09:14
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Re: Bumper Wood
This is an interesting thread, but wouldn't it be easier to notch the intake arms? Given that you'd have to diassemble the bumpers, notch, reassemble. Maybe move the brackets to get additional clearance. And after all that run the risk the inspection fails...
Isn't creating two new arms with a bend or notch easier?
