Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 12-03-2014, 13:45
Re: VEX Ultrasonic Sensor not functioning
The code and wiring should be pretty straightforward. Can you show us the relevant part of the program, and a picture of how the sensor is connected?
Unread 12-03-2014, 16:26
Fej Fej is offline
FRC #1672
Fej is an unknown quantity at this point
The connector labeled INPUT is plugged into digital I/O pin 2. OUTPUT is plugged into pin 1. Wires are black to black.
Constants:
public final int[] ULTRASONIC_PING_CHANNELS = {1, 3}; //The digital output channels where the cRIO sends a signal to the utrasonic sensor
public final int[] ULTRASONIC_PONG_CHANNELS = {2, 4}; // The digital input channels where the cRIO reads the output from the ultrasonic sensor
In the Robot() constructor:
leftSensor = new Ultrasonic(ULTRASONIC_PING_CHANNELS[0], ULTRASONIC_PONG_CHANNELS[0]);
leftSensor.setEnabled(true);
leftSensor.setAutomaticMode(true);
rightSensor = new Ultrasonic(ULTRASONIC_PING_CHANNELS[1], ULTRASONIC_PONG_CHANNELS[1]);
rightSensor.setEnabled(true);
rightSensor.setAutomaticMode(true);
Called every loop in operatorControl():
private void storeUltrasonicDistances() {
ultrasonicDistances[0] = leftSensor.getRangeInches();
ultrasonicDistances[1] = rightSensor.getRangeInches();
We're using SimpleRobot.
Since we don't know whether to plug the INPUT plug into the ping port and the OUTPUT plug into the pong port or vice versa, we tried both combinations (to no avail).
Thanks!
Unread 16-03-2014, 12:01
Fej Fej is offline
FRC #1672
Bump.
Unread 14-01-2015, 16:33
FurryFaust's Avatar
FurryFaust FurryFaust is offline
FRC #0334
FurryFaust is an unknown quantity at this point
I am having the same issue so bump.
Unread 14-01-2015, 19:43
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
The "input" of the sensor is what you trigger to send out the pulse.
The "output" of the sensor is what the time loop is looking for.
You need to have the white wire connected since that's the signal wire. Red is power, black is ground
In your example the sensor input would be 1,3. Output on 2,4
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
