Go to Post MORAL: Always wear safety glasses when you're putting on your safety glasses. ;) - Joel Glidden [more]
Unread 13-03-2014, 11:26
18mfogwell's Avatar
18mfogwell 18mfogwell is offline
AKA: Michelle Fogwell
FRC #4460 (Green MASHine)
18mfogwell is an unknown quantity at this point
Motor only responds to one way
We are programming with the Attack 3 controller and the motor only goes down.
What should the program be to have the motors go back up?
Key points:
  • We are using the Y axis
    We can only get the motors to go down
    Using NetBeans
Unread 13-03-2014, 11:32
Andrew Lobos Andrew Lobos is offline
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
Re: Motor only responds to one way
Are you doing anything before calling the motor controller's set() method? (deadband check, scaling, etc)
When you move the joystick in the up direction, does your motor controller show it is receiving a signal to move in that direction? If so, there may be a mechanical reason that the motor isn't moving rather than software/electrical.
Unread 13-03-2014, 11:43
18mfogwell's Avatar
No deadband check or scaling.
The upward motion of the robot has worked before when on buttons, just not through the axis.
This is what the part of the program is currently.
Pulley.set(operator.getY());
Problems with this?
Unread 13-03-2014, 12:07
Code-wise that is fine.
Does the motor controller LED react to movement on the joystick?
Also, if you're using Jaguars: I know they have a feature where you can have it handle checking for limit switch stops. I haven't used Jags since 2011, but based on the guide (http://content.vexrobotics.com/docs/...artedGuide.pdf) you should have two vertical jumpers on the far right pins.
Unread 13-03-2014, 12:12
18mfogwell's Avatar
Both LED lights stay solid.
We have the jumpers on brake, if that's what you are saying.
Unread 13-03-2014, 12:30
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
Make sure there are 2 jumpers set as such in this picture. If so, re-seat them:
Unread 13-03-2014, 12:38
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
They can be turned 180° (automatic ramp mode), but they need to be there.
Unread 13-03-2014, 13:52
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
What do you mean by "both" LED lights? There is one LED and it can be one of three colors - Red, yellow or green. yellow is neutral (break in your case). When you say solid, do you mean you get a solid red in one direction and solid green in the other? I believe if it thinks it hit a limit switch, it will blink the direction color. If you only see one color, there is an issue with your commanded value. If you square the joystick value, remember to do joyY * abs(joyY) to preserve the sign.
Unread 15-03-2014, 21:47
18mfogwell's Avatar
Oops that was a mistake.
The jaguars color doesn't actually change. It stays a solid scarlet color the entire time even when in moves in the one direction and doesn't move in the other.
I do not square the joystick value, should I?
Unread 15-03-2014, 22:21
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
Some drivers find that this increases responsiveness, but it is definitely not required (nor will it fix your issue, I think it was mentioned because it will cause the symptoms you are experiencing). If you do, though, make sure you either square it as gpetilli mentioned, or cube it, to allow for negative values.
Is this an issue with the one joystick, or do you guys have extra joysticks to use instead?
Currently a student at the University of Toronto - Mechanical Engineering
FRC 781 alumni
Unread 15-03-2014, 22:22
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
We always use it like this:
Pulley.set(operator.getAxis(Joystick.AxisType.kY);
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 15-03-2014, 22:28
18mfogwell's Avatar
I just cannot get the program to work on the Y axis. The program for the buttons work fine on the same controller. I thought the code was fine, but obviously not since it isn't working.
Unread 16-03-2014, 00:01
Show us your program if you want us to look it over.
Unread 16-03-2014, 10:16
18mfogwell's Avatar
Would the Joystick be replaced as "operator" and AxisType replaced as "Y"?
In other words, is this how the code would look? What would need to be replaced?
Unread 16-03-2014, 10:22
18mfogwell's Avatar
Here is the some of the operator control period:
public void operatorControl()
double joyL, joyR, joyF;
joyL = joyR = 0;
double speed, Fspeed;
while ( isOperatorControl() && isEnabled() )
if(RightDriver.getRawButton(5))
speed = 0.88;
else if(LeftDriver.getRawButton(5))
speed = 0.88;
else
speed = 0.88;
joyL = 0.7*LeftDriver.getRawAxis(2) + 0.3*joyL;
joyR = 0.7*LeftDriver.getRawAxis(4) + 0.3*joyR;
//System.out.println(LeftDriver.getRawAxis(4));
//DriverStationLCD.getInstance().println(DriverStati onLCD.Line.kUser1, 1, "Left: " + joyL*speed + " ");
//DriverStationLCD.getInstance().println(DriverStati onLCD.Line.kUser2, 1, "Right: " + joyR*speed + " ");
drivetrain.tankDrive(-joyL*speed,-joyR*speed);
