Go to Post I shouldn't be doing a happy dance or anything, should I? - Qbranch [more]
Unread 13-03-2014, 11:38
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Connect Arduino to cRIO
How would I go about wiring my Arduino uno to the Digital Sidecar for use as a slave through I2C?
I tried just wiring up pins A4 & A5 to the SDA ans SDL lines but that did not work...
I was reading somewhere that those two lines need pullup resistors, is this true and will this make a difference?
Thanks, Chiller!
Unread 13-03-2014, 11:49
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Connect Arduino to cRIO
Grab an NXT cable and cut it in half. Wire the SCL / SDA pins into the cable for the Clock / Data lines, respectively (pinout). Connect the NXT plug into the gray NXT-like plug on the Digital Sidecar. Huzzah!
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 13-03-2014, 12:08
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Use ground as well to give the sidecar/robot a common ground with the Arduino.
Also, in your Arduino code, you will need to set the clock speed for the I2C (Wire) library to the same as the cRIO/sidecar. Add the following line to your code, PRIOR to the wire.h include:
#define TWI_FREQ 38400L
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 13-03-2014, 13:00
Would you happen to know if I need those pullup resistors?
Unread 13-03-2014, 13:33
There are internal pullups on these lines in the sidecar, so you do not need to add additional pullups. Just connect the sidecar outputs directly to the Arduino A4/A5.
