Go to Post For example an iron block is very simple and very robust. Strap a control system on it and it will meet the requirements of being a FIRST robot. However, it sure doesn't do very much, nor is it innovative. - sanddrag [more]
Unread 13-03-2014, 09:09
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
FRC Blog - It Wasn’t Against the Rules
http://www3.usfirst.org/roboticsprog...inst-the-Rules
First, I’d like to clear something up. Last week I blogged about an alliance calling a timeout to give their opposing alliance a chance to make repairs.
I’ve received a few emails since then indicating some folks think this was a violation of T19, which prohibits the transfer of timeouts between alliances.
This was not a violation of T19. The red alliance did not hand their timeout coupon to the blue alliance for them to use. The red alliance used their own timeout themselves. As there are no requirements in the rules stating an alliance must use their timeout coupon only to make repairs for themselves, no rules were broken.
FMS Progress
While the FMS is performing better than it was in Week 1, we continue to work on improvements. Last Saturday, a software update was released that corrected an issue causing some ref screens to stop responding to input under certain circumstances. We are currently working on the occasional issues of auto goal timing being off and pedestal lighting delays. These issues have sometimes led to replays, which FIRST and event staff want to avoid as much as the teams do.
Mt Olive District Event Match Timing
This week I learned that most of the matches played at the Mt Olive District event in Week 1 were 20 seconds too short. Instead of being played with 10 seconds of Autonomous and 140 seconds of Teleop, they were played with 10 seconds of Autonomous and 120 seconds of Teleop. While the default times in FMS were set correctly, if FMS was shut down, then restarted, it was possible for the system to reload the match times from last year. The default times last year were 15 seconds of Autonomous and 120 seconds of Teleop. We believe the error in the Autonomous period was caught at the time and corrected at the event, but Teleop was not, leading to a split of new Auto/old Teleop times being used. This issue was not the fault of field personnel – they did a great job catching the Auto timing issue, and the Teleop timing issue was much less obvious because of the way the screens are configured. If anyone at the event noticed the matches were shorter than they should have been when the event was going on, it was not brought to the attention of field personnel, or at least we have no reports of that.
As background, match times are not ‘locked’ to allow for troubleshooting. There may be cases in which the FTA wishes to run short Auto or Teleop periods to test the system.
This bug in the system has been fixed, and we’ve thankfully had no other reports of this issue, but this does not correct the fact that this happened, and teams were impacted, for which I apologize. As we have no way to know exactly how the event results may have changed with longer matches, all results will stand. Again, I’m sorry for this issue.
Frank
Hopefully, everything can be fixed before actual matches start at most events tomorrow.
Unread 13-03-2014, 11:23
maddoctor90's Avatar
maddoctor90 maddoctor90 is offline
AKA: Matt
FRC #2481 (Roboteers)
maddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to behold
Re: FRC Blog - It Wasn’t Against the Rules
I would rather replay a match than have it scored wrong because a pedestal didn't light up. In fact, if a pedestal doesn't light up within a reasonable time (5-10 seconds) I think the match should be immediately stopped and replayed.
Unread 13-03-2014, 11:31
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
I agree 100% so do we have another ref to watch for this? Hum, more ref's great idea, we need them.
Okay all kidding aside, the delay(s) in FMS is playing havoc with this years game and putting many at wits end. What will help is software changes in the FMS and of course more refs.
With all the problems I would sure like to replay week 1 at it almost seems like we are the testing ground for the game.
Unread 13-03-2014, 11:53
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Speaking of issues, does anybody have a feel for whether incorrect scores were less frequent in week 2 after they increased the referee numbers and shifted focus to scoring over calling fouls? I think the incorrect scoring was the biggest issue in week 1; getting credit for only two assists when an alliance actually made three assists is a pretty huge problem. It's also a huge issue when an alliance doesn't get credit for all of its autonomous scoring.
(Yes, I realize that three robots can possess the ball and still not achieve three unique robot-zone pairs, so some of the perceived scoring errors were not actually errors)
Unread 13-03-2014, 12:00
Joining the 900 Meme Team
FRC #0079
I distinctly recall there being comments on the FRC Blog. Wonder why those got turned off...
Unread 13-03-2014, 12:11
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
It looks like they were turned off starting with the post November 22, 2013:
http://www.usfirst.org/roboticsprogr...Adds-Additives
All posts before that still have comments enabled, that one and all after it don't have comments. I don't recall ever reading why comments were turned off - maybe it was just too much work to moderate and reply to the comments?
2016: Lake Superior WFFA
Unread 13-03-2014, 12:13
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Didn't they also say that 'Frank Answers Fridays' would return when build season started? Well...
Unread 13-03-2014, 12:26
Best Available Data
FRC #1778 (Chill Out!)
The interesting thing is that in 2006 it became "in vogue" to call a cascading timeout to help your opponent finish fixing their robot. FIRST outlawed it the following year, presumably since it contributed to blowing event schedules.
2007 CD Discussion
Brando's got a great point too.
Originally Posted by Brandon Holley
Over this years, giving the other alliance your timeout has turned from a very gracious action, to a basically expected one. Honestly you do not really have a choice, because if you DIDNT give them your timeout you were being "un-GP".
Unread 13-03-2014, 13:58
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
2007 CD Discussion
My sense is that it's become expected in final matches, not so much earlier in the eliminations.
Unread 13-03-2014, 14:21
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
They are on for me. Maybe you are special?
Unread 13-03-2014, 14:24
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
This is why I didn't like that Frank made the post the way he did - he's only contributing more towards it being an "expected" action to give up a very valuable resource, when your opponents may have brought the problem upon themselves. I'm not saying teams shouldn't do it, but...
Does anyone else remember when TBA signatures actually worked?
Unread 13-03-2014, 14:26
FRC #0079
They were off when I looked. I even checked a half dozen other posts. They WERE off. Apparently they've since come back on.
Unread 13-03-2014, 14:28
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
So maybe the other Frank reads your posts and you really are special?
Unread 13-03-2014, 14:30
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Looks like they are back, I loaded the blog post earlier where they did not appear and then I hit refresh and boom, comments!
I suspect they comments were turned off due to kickoff and because they wanted to push users to the Q&A.
Unread 13-03-2014, 15:22
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Well they did use their time out before the 3rd match of the finals and it was a serious hit from one of their robots that caused the damage that needed to be fixed. So the time out was going to go to "waste" if it wasn't used at that point and while you may not be able to say that the damage was solely their fault they certainly played a part in it.
As a mentor for one of the teams that benefited from their use of their timeout it certainly looked like it wouldn't really hurt them. In the second match we scored fewer points during the entire match than they did in auto and only won due to foul points. However for that 3rd match our alliance got our act together and started doing full 3 robot assist cycles and frankly played the best match that they had played together.
