Go to Post The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it. - dlavery [more]
Unread 10-03-2014, 22:34
yash101 yash101 is offline
AKA: null
NetworkTables C++
This has been something I have always stumbled upon. This year, I am aiming to seamlessly integrate two systems together, one being the main robot code written in Java, and the other being the vision code running in C++. I am going to have my vision code run in Embedded Linux (ARM). I have not been able to find any good source for a library that will allow me to easily use NetworkTables.
Please point me to some resources. I wish to create a thread with a good answer so anyone else shot in the dark like me will have an easy time
Good Luck and Thanks!
Good Luck with your season and competitions!
Unread 11-03-2014, 00:09
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: NetworkTables C++
You can run pynetworktables on a pc, but that requires python.
Alternatively, you can use the source code that pynetworktables is compiled from to build a C++ version of the library (as it is C++ underneath).
Cross-platform files required: https://github.com/robotpy/pynetwork...ree/master/src
Patched wpilib source that will compile on Windows and Linux: https://github.com/robotpy/wpilib
Unread 11-03-2014, 12:47
AKA: null
I did look at the pyNewtorkTables GitHub but I couldn't understand what was really happening. Can I compile it and run include it in my OpenCV program?
Unread 11-03-2014, 12:51
virtuald's Avatar
RobotPy Guy
Yes, you can extract the pieces that you need and compile them all together.
pynetworktables is a python program, and setup.py dictates what files are compiled and how they go together. However, if you use the source code that I linked to above, and compile it all together, you should end up with something that will be usable from C++. It may not be pretty, but currently nobody provides an easy way to build NetworkTables from C++.
Unread 13-03-2014, 15:26
AKA: null
I will try that during the offseason and probably make that available for everyone's life easy
Unread 14-03-2014, 16:09
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Why go through the hassel of using network tables. My experience with it is the bugs are not worth the trouble.
Create a simple TCP socket between the C++ code and the Java code.
Make the robot the server, and the c++ code the client and send ascii data between the two.
Make sure you run the read/write in their own threads so there is no i/o blocking.
You can control the communications, the ports, and the data being sent - no need for network tables really.
Use pthreads on the C++ side, and ServerSocketConnectionclass on the java (crio) side. Those classes are already apart of the codebases you are targeting and no need to have additional interpreters installed or rely on WPI library implementation.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 15-03-2014, 15:42
AKA: null
Yeah. I need to give that a try. First, however, I need to get our pretty ODROID up and running
I realised that the ODROID that we recieved is twice as powerful as my new laptop and much more powerful than any of our team's laptops!
