Go to Post The fact of the matter comes down to this: No matter what you are interested in, you can always encourage others. - Amanda Morrison [more]
Unread 14-03-2014, 10:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: paper: 2014 HOT Tech Notes
Interesting design analyses.
I thought 254's '08 bot was a much better bot to emulate for this year's game than 1114's '08 bot. Simple lift, softer launches and a similar roller intake/outake - much more controllable than a punch. I suppose c.g. would be an issue, but with the ball in the 'up' position c.g. is an issue with 1114's design too.
Turns out either would work for specific robots, but 1114's probably better for the high goal. Yet I was more biased towards being the best ball handler than the best high goal shooter.
Tom, here you go:
http://www.chiefdelphi.com/forums/sh...2&postcount=12
GitHub
Unread 14-03-2014, 12:49
Chris is me's Avatar
AKA: Pinecone
I can't speak for HOT, but oddly enough this exact same logic is why we went with an 1114 claw. Building a bulletproof claw intake was way easier for us, and the rest of our design was driven around the claw.
Beautiful machine HOT. That backwards fire is so clutch, can't wait to see that win you some matches. Squeezing every second out of a cycle is key and it looks like you guys have it
Unread 16-03-2014, 10:53
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Tom, here you go:
We like both designs as concepts to work from. But we felt that the 1114 design was superior (atleast in 2008) for both ball collecting and high goal scoring.
As Chris mentioned, we basically started with the claw concept and designed around that.
One of the biggest benefits we saw in the 1114 design was the ability to get balls out of tight spaces. It's still pretty true....but the top roller with out side bars does require a higher level of driver precision than the Bombsquad (top roller and side bars design). 1114 had one of the best drivers EVER in 2008. Teams should take that into account when they are evaluating designs from past games.
We will probably need to add something to our design to assist with ball centering to make it easier to collect the ball. Right now that is one of the areas we can improve on greatly.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 17-03-2014, 19:02
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Great read. I always love looking at any robot 67 builds. You guys have made some great marvels of engineering and this year is certainly up to that standard.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 17-03-2014, 19:17
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Thank you so much for this. When our team did terrible in 2013, I spent days looking over things like this. I ran into your tech notes and it was like I struck gold. I showed this to our head engineer and we decided to do what you did. We used waterjet 5052 1/16" aluminum and lowered the pneumatics use. We also did our own little spin by adding some mounting holes, cable management holes, and some strain reliefs built in to the chassis. We even had to buy our own 5052 stock because Chrysler (or fiat now ) only had 6061.
In short, thanks. This really helped us get a good base down to start tinkering with.
Unread 18-03-2014, 08:09
Forever HOT!
Chad, thanks for the kind words...I'm glad that the tech notes are being used.
We were really impressed with your machine and driver's at Howell. Keep it up!
Looking forward to seeing you in Lansing.
-Adam
Unread 19-03-2014, 18:47
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Adam,
Thanks for sharing the Tech Notes again this year. I finally got a chance to read them, after watching some of your matches of course. It is always cool as an engineer to know how something works and some of the thoughts throughout the process.
Good luck the rest of the season and hopefully I can see this beast of a machine at Champs!
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 01-04-2014, 08:38
Forever HOT!
Since we weren't able to finish our premier night reveal video in time, we waited until we had additional footage to publish a video.
Fresh from the HOT Team Promotional Department is a video featuring our robot at the Howell District: https://www.youtube.com/watch?v=pHBzLlr8aso
Additional videos from Waterford can be found here: https://www.youtube.com/watch?v=-AGQ...zK-g_bv4hkgwwd
Enjoy!
Unread 01-04-2014, 08:56
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Enjoy!
Good song choice. The last time I remember a team using that song in their reveal video they won The World Championship.
Unread 01-04-2014, 10:04
Forever HOT!
Nice!!! I wish I could say that was intentional, but unfortunately that might be the only Robowrangler video I have never watched.
But, I am not suprised that us and 148 would choose similar music:
http://instagram.com/p/jUvPJGn23l/
