Go to Post Success is the indescribable feeling you get when you see something you worked so hard on in front of thousands of people. - SlamminSammy [more]
Unread 14-03-2014, 17:58
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Mounting compressor upside down
It is probably caused by some sort if leak in your air system.
How much storage are you using?
Also I assume you know that you may store air at 120 psi and the working pressure is a maximum of 60 psi.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 14-03-2014, 22:21
Coach,
There is no rule about compressor orientation but there are a few things to consider.
1. If you use the rubber isolators to mount, they are not intended to be used in tension and so have a tendency to fail over time.
2. The compressor gets hot and heat rises, putting the heat back into the compressor body.
3. It hard to see if it is running by looking into the robot.
