Go to Post Bless you sire and all your HD camera goodness. - pyroslev [more]
Unread 14-03-2014, 22:34
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: [FTC]: Using TETRIX work gear assembly.
Originally Posted by link View Post
We are seeing the same problems. Those set screws are not very strong. Did you ever find a better solution than glueing them all together?
No, and in the end we abandoned the worms altogether. No matter what we did the gear/shaft coupling ended up failing. My motto has always been never to use the shaft to transfer the high torque, and this turned out not to be an exception to the rule.
The alternate solution was to use smaller pinion gears on the motor to direct drive a tetrix gear.
Servo city (among others) has some compatible 32 pitch gears that fit nicely on the Motor shaft, with very low tooth counts. Specifically 16 - 24 tooth.
https://www.servocity.com/html/32_pi...l#.UyO65ibD-70
By combining one of these with an 80 or 120 tooth gear you can get some high ratios... eg: 16 - 80 tooth is 5:1 16-120 is 7.5:1
On our arm, we used the 16:80 and then followed by as 40:80. The 10:1 was enough to lift our robot.
Phil Malone
http://www.GEARSinc.org
Unread 15-03-2014, 16:46
WIREDFTC's Avatar
WIREDFTC WIREDFTC is offline
More hot glue!
FTC #5035 (WIRED)
Team Role: Webmaster
WIREDFTC has a spectacular aura aboutWIREDFTC has a spectacular aura about
My solution to that would be to drill small holes, in the axle for the set screws to sit in so it transfers torque between the gear and shaft better, and then you can combine that with loctite.
