Go to Post Duct tape is like the Force - it has a dark side and a light side and it holds the universe together. - Jnadke [more]
Unread 11-03-2014, 15:28
Rochester2909 Rochester2909 is offline
FRC #2909
Rochester2909 can only hope to improve
Help Us
If you could look at these pictures and tell us whats wrong
Unread 11-03-2014, 15:31
FRC #2909
Re: Help Us
Unread 11-03-2014, 15:33
randantor randantor is offline
AKA: James Y
FRC #0624 (CRyptonite)
randantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of light
Re: Help Us
Edit: just saw the pictures posted in the thread
As far as I can tell, your solenoid code looks all right. Could you be more specific on exactly what you're having trouble with?
One thing to note is that the Motor Set Output VI expects a floating-point value from -1.0 to 1.0 , where -1 is full reverse, 0 is stop, and 1 is full power forwards. You seem to be giving it an integer from 0-255, which probably won't work the way you are expecting it to. Any value higher than 1 will be interpreted as full power forwards.
Unread 11-03-2014, 15:39
Re: Help Us
You open joystick 1 and joystick 2, but only use joystick 1. You don't show Periodic Tasks, so I can't tell if the Compressor code is in place and using the correct string.
You are also using last year's template. This will be fine, but it is more difficult to delete the camera stuff if you aren't using it.
Did you have specific issues you wanted help to understand?
Greg McKaskle
Unread 11-03-2014, 15:59
FRC #2909
Re: Help Us
One thing to note is that the Motor Set Output VI expenging-point value from -1.0 to 1.0 , where -1 is full reverse, 0 is stop, and 1 is full power forwards. You seem to be giving it an integer from 0-255, which probably won't work the way you are expecting it to. Any value higher than 1 will be interpreted as full power forwards.
Thanks for the numerical range! That was something I have been searching for, but have yet to find.
Our problem is that when we attempt to test the code, we receive no response from the robot, yet the diver station reports no errors. Currently, we are searching for a wiring malfunction.
Unread 11-03-2014, 16:14
FRC #2909
Re: Help Us
Greg McKaskle
Here is periodic tasks. We have not programmed anything onto the second joystick because we had an issue where the values of other joysticks were misread.
Unread 14-03-2014, 09:51
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Re: Help Us
I'm pretty sure for a double solenoid, you need to actually tell it forward or backward, not just true or false. You can do this by using the selector and a couple constants.
you can also use the selector for your motor values which can be numbers from -1 to 1, not 0 to 255
Per Audacia Ad Astra
Unread 14-03-2014, 23:55
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Re: Help Us
Yeah I'm pretty sure you need to define direction of a single solenoid. It's a constant on the 'Set' block.
