Go to Post Don't you just wish life had a redo button? - DHarris [more]
Unread 08-03-2014, 14:57
ChiHopeRookies's Avatar
ChiHopeRookies ChiHopeRookies is offline
Rookie Team
ChiHopeRookies can only hope to improve
computer wont boot up
2gopc startup saying BOOTMGR IS MISSING.
We had someone that knew about software and that kind of stuff come in and help us set up our 2go pc. They left saying that something was wrong with the computer and that they couldn't do anything. Right now we tried to set it up so that we could control our drive train and it says that the BOOTMGR is missing. We tried booting up from a USB loaded with Windows but it won't recognize the USB. Now we have no way of booting it up since we can't even access the main menu, not even through MS-DOS mode.
Unread 08-03-2014, 15:00
Re: computer wont boot up
Did it use to work, and now it doesn't? If so, when is the last time it worked, and what was done to it since then?
https://www.google.com/#q=BOOTMGR+IS+MISSING
Unread 08-03-2014, 15:05
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Have you imaged the Classmate with the imaging key? I know that Classmates received through First Choice were not imaged. I'm not quite sure about those received in the actual Kit of Parts though.
If it was imaged, try following a few troubleshooting steps to see if you can fix it. If it hasn't been imaged yet since you received it, follow the steps here to load an operating system on it.
I'm right 90% of the time, so why worry about the other 3%?
Unread 11-03-2014, 16:49
2gopc startup saying BOOTMGR IS MISSING...
Did you resolve this?
Unread 15-03-2014, 10:39
Nunez4296's Avatar
Nunez4296 Nunez4296 is offline
Programmer
AKA: Joseph Nuņez
FRC #4296 (Trident Robotics)
Nunez4296 is an unknown quantity at this point
We had the same problem when trying to image an HP Probook 6360b, I believe it is a problem with the current image from the FIRST website unless your computer used to work.
Unread 15-03-2014, 11:00
Jared's Avatar
Jared Jared is offline
The provided image from FIRST only works on the classmate computers.
Unread 15-03-2014, 11:22
yash101 yash101 is offline
AKA: null
Boot from a USB key, loaded with Ubuntu. Once you boot in, connect to the network. Run the following commands:
sudo apt-get update
sudo apt-get install boot-repair-disk
run boot-repair-disk and you should have an option to install grub (or maybe even install windows boot mgr). Start with installing grub, and keep it if you like, otherwise once you boot into windows, use windows to reinstall the boot manager. That should do the trick, typically. What did you install that broke the system?
Unread 15-03-2014, 12:33
Nunez4296's Avatar
Programmer
AKA: Joseph Nuņez
We first tried with the FIRST image, and then image software from the HP website. Sorry i didn't clarify this.
Unread 15-03-2014, 12:38
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
That's not true, we've used the classmate image to image a thinkpad. Although I think your success will vary.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 15-03-2014, 12:41
Nunez4296's Avatar
Programmer
AKA: Joseph Nuņez
I believe this is true but I cannot verify, we did image another HP laptop last year but for whatever reason, it didn't work for our new laptop this year.
Unread 15-03-2014, 12:56
AKA: null
What is this dark magic?!
I really think it is a question of luck, hit or miss. It could also be caused by small hardware differences. There really isn't a true explanation to this phenominon, but I think this might have happened!
Unread 15-03-2014, 13:04
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yeah, we tried to E14 image but that one bluescreened it even in safemode. We had to go back and use the e12 image.
Kevin Li
596 - Sciclones
